Go to Post There's more to the game then winning. - Gabriel [more]
Unread 06-01-2013, 10:32
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
Conneting to camera without using dashboard in competition.
Hello, I was wondering if it is possible and legal to connect my driver laptop to the robot's axis camera without using one of the supported dashboards. The camera would be linked up to the bridge. Also this is a completion specific situation as I already know how to connect to the camera though a normal network.
Unread 06-01-2013, 10:34
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
Re: Conneting to camera without using dashboard in competition.
Just curious, why would you choose not to use one of the default dashboards?
Unread 06-01-2013, 10:43
FRC #0486
I want to do image processing on the laptop, but not using the default dashboard codes. It may be possible to pull the feed from a dashboard which would be fine. But it would be simpler to connect straight to the camera.
Unread 06-01-2013, 10:48
As long as all of your communication goes over the ports listed in R59 and the stream you open stays under the bandwidth limit you should be fine.
You may also find the FMS Whitepaper of interest.
Unread 06-01-2013, 10:54
FRC #0486
Thanks ruff, I will check that out.
Just to clarify you are saying I could use for example ports
5. HTTP 80
6. HTTP 443
R59
Communication between the ROBOT and the OPERATOR CONSOLE is restricted as follows:
A. Network Ports: 1. TCP 1180: This port is typically used for camera data from the cRIO to the Driver Station (DS) when the camera is connected to port 2 on the 8-slot cRIO (P/N: cRIO-FRC). This port is bidirectional.
2. TCP 1735: SmartDashboard, bidirectional
3. UDP 1130: Dashboard-to-ROBOT control data, directional
4. UDP 1140: ROBOT-to-Dashboard status data, directional
5. HTTP 80: Camera connected via switch on the ROBOT, bidirectional
6. HTTP 443: Camera connected via switch on the ROBOT, bidirectional
Teams may use these ports as they wish if they do not employ them as outlined above (i.e. TCP 1180 can be used to pass data back and forth between the ROBOT and the DS if the Team chooses not to use the camera on port 2).
Unread 06-01-2013, 11:00
5. HTTP 80
6. HTTP 443
Exactly. You could use any of the ports listed there, but given that those two are specifically called out for the camera I would guess those are the ports it talks on (at the very least by default)
Unread 06-01-2013, 11:05
FRC #0486
Thank you very much that answers my question!
Unread 06-01-2013, 18:11
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
So if I use a odroid to do vision processing on the robot it should not matter what port I am using. I am routing on the robot. Is this correct?
Unread 06-01-2013, 19:37
See Rule R58 for a set of ports to avoid.
