Go to Post I don't want a carbon copy of your wheels.. I want to improve upon your design. - Tom Bottiglieri [more]
Unread 06-01-2013, 11:47
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Can we THROW through the feeder slot?
One of the first questions I had when i saw the video. Anyone that's thrown a frisbee down against the ground knows how it bounces back up and goes a lot farther. The feeder slots in the video looked about 45 degrees down (though admittedly I havent seen the blueprints yet).
Did anyone else think about this? Happen to see a rule about it that I missed? If it's not prohibited this would be a great strategy to feed them to your robot across the field
Team 3753 BulahBots
Unread 06-01-2013, 11:52
Twest3259 Twest3259 is offline
Murray State University Student
AKA: Travis West
FRC #3843 (RoboRacers)
Twest3259 is an unknown quantity at this point
Re: Can we THROW through the feeder slot?
I don't see anything against it in the Manual, so I would say yes that's perfectly legal. because you are putting the Game piece through it's intended slot.
Unread 06-01-2013, 11:55
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Section 2.2.7
All of the FEEDER STATIONS consist of a 44 in. wide shield of clear polycarbonate. In the center of the shield are three horizontal FEEDER SLOTS, 12 in. wide by 3 in. high. These slots are located 22 in., 42 in. and 62 in. from the FIELD carpet to the bottom of the slot. Each slot has a slide attached to it on the FEEDER side of the plastic. These slides are 8 in. long and are at a 30-degree incline.
(my emphasis)
I imagine that it would be hard to throw a frisbee through an eight inch long slot. Anybody tried yet?
Unread 06-01-2013, 11:58
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Originally Posted by nnfuller View Post
Section 2.2.7
(my emphasis)
Can we make a device to throw it accurately through the slot or is that not allowed?
Unread 06-01-2013, 12:04
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
I don't think that would be allowed.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 06-01-2013, 12:07
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
G34 Only FEEDERS may touch DISCS. Inadvertent or inconsequential contact by others will not be penalized. Violation: FOUL
Section 2.2.7
(my emphasis)
I don't see the eight inches being the problem, I see the incline being the problem. If you actually want to throw the disc through the slot, you're going to be aiming straight down, and drawing it out makes me wonder whether a bounce shot through that slot is even possible.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 06-01-2013, 12:28
ttldomination's Avatar
Sunny
Looking at the videos and pictures of the feeder station, it's definitely going to be a tight fit if you plan on throwing them.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 06-01-2013, 12:31
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
We were at the kickoff with the real field and there is going to be no way to throw through the feeder slots. You might be able to push really hard and have it go a little further, but there won't be enough momentum to bounce and go further. The slot is really just big enough for the disks, to the point that several people got them stuck in there a bit when trying to push them through.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 06-01-2013, 12:39
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
I'm not undstandimg how the slots are 8 inches long. Aren't the frisbees 10.625 inches wide in diameter?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 06-01-2013, 12:40
ctccromer's Avatar
Animus
I guess that's that then. Thanks
Team 3753 BulahBots
Unread 06-01-2013, 12:42
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
The incline is 8 inches and it is open on the ends. The slot itself is wider and taller than the Frisbees (12x3)
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 06-01-2013, 12:45
slijin's Avatar
Pockets
AKA: Samuel Lijin
Wow. How exactly did they get them stuck? All I can imagine is that the far lip of the disc rubbed up against the top of the slot as they pushed down the close end of the disc, and since the stuff is polycarb I find it hard to believe that the friction would be strong enough to do that.
As Trent said, the slots themselves are 12" wide and 3" tall. The 8 inches refers to the length, or depth, of the tube that it has to pass through as it goes into the field.
Unread 06-01-2013, 13:40
Division by Pirates
Ah, thank you for the clarification.
