Go to Post My robot is my significant other. It makes me happy, sometimes it makes me sad, i wish it would lose some weight but it is always there for me. - rachelholladay [more]
  #46   Spotlight this post!
Unread 05-01-2013, 23:10
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Climbing In 3 Sections
Originally Posted by gburlison View Post
What is your interpretation of G4 ?
"3.2.1.4 G04
ROBOTS may only be removed from a PYRAMID under the following conditions:
A. by the TEAM,
B. unpowered,
C. and under the supervision of a FIRST Technical Advisor (FTA), FTA Assistant, Referee, or Field Supervisor.
Additionally, if any part of the ROBOT is in Level 3, TEAMS are required to attach a FIRST supplied belay line, detailed
in Section 2.2.6, to their ROBOT to spot a ROBOT while the TEAM removes it from the PYRAMID."
I dunno, it seems pretty straightforward to me.. The TEAM removes the robot (not another team or FRC volunteers/staff)
The power must be off
The FTA, FTAA, Ref or FS must be watching
And if you are at level 3, wait for FRC folks to direct you with the Belay thingie.
Originally Posted by Redo91 View Post
Emphasis mine.
This rule reads a little funny at first, but when you take it for exactly what it says, I think it becomes clear. There is nothing about how many zones the robot can occupy, but how many different zones the robot may contact. This is why the planes for the zones are above the horizontal members.
Let's say you are going to score on the second level (20 points). Your first step, following G22, would be to move from level 0 (the ground) to level 1(fully supported by the section of the pyramid in zone 1). You are now free to move on from the section of the pyramid in zone 1 to the section in zone 2.
I hope this is a helpful explanation.
Yes, it does. It is clear to me that the AIR around and within the pyramid is NOT the pyramid. Contacting the top of the first bar is NOT touching any of the second zone of the pyramid. Sure, it touches AIR in the second zone (by the thickness of your hook), but not the pyramid.
I would still like to see a Q&A submission asking if a robot grappling the lowest (30") horizontal bar with a hook is occupying 2 zones (legal) or 3 zones (illegal, because of the slight projection of the hook into Zone 2, plus contact with the floor (zone 0) and the first horizontal bar (zone 1).
  #47   Spotlight this post!
Unread 05-01-2013, 23:24
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Only as difficult as you design it to be.
Sorry, I meant legally. If the issue is contacting pipes within each zone (agreed), is it legal* for a robot to grasp the corner joint of the 30" pipe and of the 60" pipe? (Essentially analogous to your original explanation, which I agree with, but brought next to objects that run the full heights of the zones, obfuscating "occupy".) This is not to say that climbing slanted pipes would be harder--a la 2010 vertical climbers--but rather to investigate the legal issues surrounding working at corner joints.
*Perhaps I should say "wise" rather than "legal". Anyone close enough to brush against the wrong side of a slanted pipe seems to be in a precarious position technical position--and making it very tough on the refs! I'd loathe to see those DS lights turn yellow...
EDIT: or, you know, what Don said. [part 2]
@Don for part 1: I think he's referring back to this concept of climbing early and then coming down to score more.
  #48   Spotlight this post!
Unread 05-01-2013, 23:38
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
I think wise is the word you are looking for. There is not much room to grab onto a corner. It would probably be a judgement call by the referee observing the robot.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #49   Spotlight this post!
Unread 06-01-2013, 10:41
u13mbenshoshan's Avatar
u13mbenshoshan u13mbenshoshan is offline
FRC #2230
u13mbenshoshan will become famous soon enough
Pyramid Rule Question
Hello to all FRC participants,
I have read throught the rules and have a question that the rules dont refer to.
Can you climb up the pyramid or begin the climb before the last 30 seconds of the match?
This question is' in my opinion very important to understanding the flow of the game and can bring new strategies to the table.
I thank you all in advance
Team #2230
We have a very close to impossible assignment. We need to build a robot in an almost impossible time frame, we need to build it with an almost impossibly strict budget, and we need to work with the minimal tools.
And yet every year we are reexcited for the challenge that will change us all.
-Matthew Team #2230
  #50   Spotlight this post!
Unread 06-01-2013, 10:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Pyramid Rule Question
You haven't found anything in the rules that says you can't. The rules have nothing in them about when you're allowed to start climbing. Ergo, you can start climbing whenever you like. The GDC is usually very specific and clear when they want to limit activities to some smaller portion of the match.
  #51   Spotlight this post!
Unread 06-01-2013, 11:08
RSaunders RSaunders is offline
FRC #2537
RSaunders is an unknown quantity at this point
Re: Climbing Rules
The top paragraph of page 6 (the end of section 3.2.4.2) has a pretty clear example:
If a CLIMB is considered unacceptable (e.g. a robot has touched non-adjacent Levels or more than 2 Levels at a time) ...
This says your robot may extend into the Levels whenever it wants (subject the the 84" rule (G22). Your robot may only touch Level 0 and Level 1 (the ground and the lowest bars) then Level 1 and Level 2, etc. Your robot must touch Levels in sequential order per 3.2.4.2.A.
  #52   Spotlight this post!
Unread 06-01-2013, 11:38
TVwazhere's Avatar
TVwazhere TVwazhere is offline
Unregistered User
AKA: TomTom
FRC #0020 (Rocketeers)
Team Role: CAD
TVwazhere can only hope to improve
Except a revision probably. That or you have 2 minutes to get it right
"Well there's your problem!" -Mythbusters
"It's Dope" -Will.I.Am, Jan 9th, 2011 FIRST Locomotion Kickoff
"Design Thrice, Measure Twice, Cut Once"- Tom Tom
"If your life was a Disney film, then this is the part of the movie where you would break out into song" - Tom Tom
  #53   Spotlight this post!
Unread 06-01-2013, 11:41
OkieSoar OkieSoar is offline
Mentor, Team 2165
AKA: Dave Register
FRC #2165 (TrailBlazers)
OkieSoar is an unknown quantity at this point
We've been discussing the same question and initially concluded that there was no restriction in the written rules about when to start the climb. However, in the game video this might remain uncertain as it says
"near the end of the match" the human players can start throwing their discs.
In the next statement, it says, "at the same time, robots drive to their pyramids and start to climb"...
These comments are at about 2:20 into the game animation video.
If you look through the rules book, specifically 3.3.37 G35-B, for when human players can start to throw discs onto the filed:
"during the last thirty (30) seconds of TELEOP"
If the 'at the same time' statement in the game animation video is firmly linked to when human players can start to throw discs, this suggests the climb can only start in the last 30 seconds of TELEOP.
Not completely sure of this interpretation but for initial planning purposes it might be prudent to plan on climbing during the last 30s. But there's no specific rule we've found so far that addresses when the climb starts other than the linkage through the game animation video.
Dave R
Mentor - Team 2165
  #54   Spotlight this post!
Unread 06-01-2013, 11:44
astronomer_bh astronomer_bh is offline
FRC #1740 (Ledyard Cyber Colonels)
astronomer_bh is an unknown quantity at this point
Re: Climbing Rules
I am trying to figure out if you can still get the 30 points if you pull your robot partially above he level 3 zone, for example, if the robot had arms pulling it up so that the bottom of the robot was above the 2nd bar, and the top of the robot extended above to even with the pyramid target
  #55   Spotlight this post!
Unread 06-01-2013, 11:50
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Climbing Rules
Does everyone believe that the rule prohibits a robot from climbing the pyramid during the match and then say scores in the pyramid goal and then lower itself to retrieve frisbees and then repeats the process?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #56   Spotlight this post!
Unread 06-01-2013, 11:53
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Climbing Rules
The disks remain in the goal, there's a basket.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
  #57   Spotlight this post!
Unread 06-01-2013, 11:57
dodar's Avatar
Re: Climbing Rules
Im not asking about the scoring part.
  #58   Spotlight this post!
Unread 06-01-2013, 12:03
snowmobiler9's Avatar
snowmobiler9 snowmobiler9 is offline
Former Team Captain
AKA: Hunter Clark
FRC #0706 (Cyberhawks)
snowmobiler9 is on a distinguished road
Re: Climbing Rules
There is nothing in the rules that i have spotted saying you cannot climb during the match as long as it is done in the proper way. One thing that i would look at though is the fact that there are only 6 Frisbees allowed to be put in the top goal
  #59   Spotlight this post!
Unread 06-01-2013, 12:04
AKA: Jesse Gibson
Team Role: CAD
Re: Climbing Rules
If there's no disks to retrieve then there's no reason to go back down. Unless you were talking about going back to get the other two? In that case, rule G4 makes that a little iffy since it says that the robot may only be removed by the team, unpowered and under FTA supervision. So you'd then have to determine if they mean that removing the robot is just at the end or any time when the robot is coming off the pyramid, in which case coming back down under robot power would be illegal.
2011 - Logomotion
  #60   Spotlight this post!
Unread 06-01-2013, 12:09
dodar's Avatar
Re: Climbing Rules
Actually this part of rule 3.1.5.2 pretty much says you can drop back down and give the climb another go to get the right climb points you want: If a CLIMB is considered unacceptable (e.g. a ROBOT has touched non-adjacent Levels or more than two (2) Levels at a time), a Referee will indicate a rejected CLIMB by turning the offending ROBOT’S PLAYER STATION LED strings yellow. The ROBOT will be ineligible for CLIMB points unless and until it begins a new CLIMB from the floor, Level 0.
