Go to Post communication at its best = quick, brief, clear - JaneYoung [more]
Unread 06-01-2013, 12:51
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
Process to update Existing JAVA Dev Workstation to 2013
Here are the steps to update an existing FIRST ROBOTICS JAVA development environment:
Backup your host
Install JAVA Software Development kit
Install Netbeans 7.2.1
Install FRC Netbeans Plugins
LabVIEW Run-Time Engine 2012
Install WPI_Required_updates (FRCUtilitiesUpdate.zip and DriverStationUpdate.zip)
Update Image on CRIO
SDK
http://www.oracle.com/technetwork/ja...s-1880260.html
Netbeans:
http://netbeans.org/downloads/
http://first.wpi.edu/FRC/java/netbeans/update/Release/
(( RENAME FROM ZIP TO .NMB)
LabVIEW Run-Time Engine 2012 - (32-bit Standard RTE) - LabVIEW 2012 Run-Time Engine (Standard)(32-bit) for Windows
http://joule.ni.com/nidu/cds/view/p/id/3433/lang/en
FRCUtilitiesUpdate.zip = http://joule.ni.com/nidu/cds/view/p/id/2261/lang/en
DriverStationUpdate.zip = http://joule.ni.com/nidu/cds/view/p/id/2263
password: sAucersFlyRobotsClimb!
Error messages:
Unable to locate the labview run-time engine, Need FRC CRIO Imaging tool requires a version 2012
Dave Frederick
Unread 06-01-2013, 13:10
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Process to update Existing JAVA Dev Workstation to 2013
Also, be sure to uninstall the previous year plugins before installing the new ones. And if at all possible, use the web-based plugin installer as described below since it will automatically notify you of updates that are released.
http://wpilib.screenstepslive.com/s/...elopment-tools
Brad
Brad Miller
Robotics Resource Center
Unread 06-01-2013, 13:20
FRC #1895
Brad,
Thanks for the feedback.
Our FRC JAVA development notebooks are not allowed to connect to the school network so we don't have any connectivity.
We need to acquire all of the software ahead of time.
In past years we had trouble getting the development environment to work, always needed to download some huge chunk of code.
This year I practiced the full process in a VM ahead of time.
I hope we can have code development working in a few hours and not days/weeks.
Dave Frederick, Manassas VA
Unread 06-01-2013, 13:34
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Originally Posted by DaveFrederick View Post
Brad,
If you need to download the plugins ahead of time, go to the directory the screensteps documentation gives you:
http://first.wpi.edu/FRC/java/netbeans/update/Stable/
And download them off the FTP directly
Then go into Netbeans and go to Tools>Plugins>"Downloaded" and click "Add Plugins," and add the downloaded plugins manually.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 06-01-2013, 18:33
AKA: Brad
There is also a zipped file of the plugins on FIRSTForge.wpi.edu in the wpilib project file releases section. Either works.
But, I have a question... the place that people should be going for the plugins is the Release directory from above (replace Stable with Release). I was curious if we missed a spot in the documentation where it says Stable? Can you post the link to that if you can find it?
Thanks
Brad
Brad Miller
Unread 06-01-2013, 23:44
F22Rapture's Avatar
AKA: Daniel A
Thanks
Brad
This is correct, my bad.
IIRC I had the other one bookmarked.
- Wernher von Braun
