Go to Post Mentors learn from, are inspired by, and emulate each other. A team with a great lead mentor leads to a productive, inspired, and ultimately successful group of mentors. - Jared Russell [more]
Unread 25-12-2012, 15:40
sunny1118 sunny1118 is offline
FRC #0224 (The Tribe)
sunny1118 is an unknown quantity at this point
Camera and kinect
Our team wants to use the kinect and the camera and we don't know where to start. So can someone help us
Unread 25-12-2012, 18:44
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: Camera and kinect
First of all, what programming language are you using?
If you're using LabVIEW and Java both have awesome vision examples built in.
Here's a link to the 2012 vision whitepaper:
https://decibel.ni.com/content/docs/DOC-20173
Here's a link to the getting started with kinect:
http://www.usfirst.org/sites/default...o r%20FRC.pdf
Also, if you search for the camera and kinect, you'll find lots of great tips.
Unread 25-12-2012, 19:04
coollint's Avatar
coollint coollint is offline
AKA: Ryan Keller
FRC #0075 (Roboraiders)
coollint is an unknown quantity at this point
If you're using labview there are vis specifically for using the kinect. The way we did it is we used 2 joystick opens in the begin vi, and then we chose kinect 1 and 2 for the 2 y axis. After that we pulled the 2 y axis values by using the kinect vertices vi (im not positive that this is the right vi), and sent the axis values to our drive vi.
Mount Olive Semi-Finalists with 1367 and 3929 and Chairmans Award Winner
Unread 02-01-2013, 17:10
so we are using java and we set it up using the setup and don't know where to go
Unread 03-01-2013, 17:07
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
For the camera, remember there is a Vision Example every year.
For the kinect, do you want to use it on the bot or in hybrid?
Unread 03-01-2013, 17:40
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Hey 224- You guys were a great partner at Lenape!
Anyway-
Yes, there is a VERY big distinction between ON the robot and at the Kinect station. Both are very possible, yet first explicitly supports the kinect at the kinect station (Duh), but if you want the kinect on your robot, that will take a LOT more work, yet it still isnt THAT hard.
Bottom like it involves putting a 2nd computer (Crio and another processor are now on the robot). Heres a good White Paper on it: http://www.chiefdelphi.com/media/papers/2698
Be sure that you REALLY want the kinect on the robot though! Its no a straight forward thing to do.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 05-01-2013, 22:55
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
For those talking about Kinect..
I've used Kinect with my xbox but we didn't mess with it last year, so I'm clueless when it comes to the controls. Is it easy to find a good place for it on the robot (after playing around a bit of course), or are you limited by certain factors? I know the camera is phenomenal but I'm unsure if it will do things like look up and down and such in order to adjust to varying distances from the goals
Team 3753 BulahBots
Unread 06-01-2013, 13:18
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
It has a servo motor in the base to tilt, but that is not intended for frequent use and will burn out if you run it too much. You are better off using an external servo motor to tilt the camera.
Unread 06-01-2013, 13:49
dheerm's Avatar
dheerm dheerm is offline
Drive Team and Head Programmer
AKA: Dheer Mirchandani
dheerm will become famous soon enough
Anyway-
Thanks, you were to!!
We don't really want the kinect on the robot. Actually since its not even required this year we could just forget about it really. It's to big I feel and the axis camera can accomplish the same things as the kinect anyway.
Our end goal is target processing but if we are able to get good spin on our frisbees, we should be able to just manually aim
"All you need is duct tape and a dream"
Team 224:
District Champions @TCNJ w/ Team 56 and Team 293
8th alliance captain at MAR championships w/ (take a guess) , Team 56 and Team 293.
www.team224.com
