Go to Post Oh End-Of-The-World CDenizens... you never fail to entertain... - JesseK [more]
Unread 06-01-2013, 14:15
akosin's Avatar
akosin akosin is offline
AKA: Austin
FRC #4288 (Worcester Beach Bots)
akosin is on a distinguished road
Pneumatic Tanks
Our team has never done pneumatics before, does anyone have any tips? Also, how many storage tanks are we allowed to have on the robot?
Thank you,
Austin
"When you’re screwing up and nobody’s saying anything to you anymore, that means they gave up."
-Randy Pausch
"The Last Lecture"
Unread 06-01-2013, 14:37
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Pneumatic Tanks
First tip: read the pneumatics rules. Then move on to CD-Media for all your presentation needs.
There's no hard limit on how many storage tanks you can keep on the robot. Just remember that the more tanks you have, the more time you need to run your compressor to refill them.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 06-01-2013, 21:31
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Pneumatic Tanks
The first tip is don't be stingy with the teflon tape. Make sure that all of your connections are sealed well, the last thing you want is to have to find a leak. Just do it right the first time, even if its not as quick as you would like.
Secondly, keep your tubes clear. If it's your first time, you will most undoubtedly have problems somewhere. Keep the tubes well organized like a good electrical system so that if you do have to deal with a problem you will have an easier time of finding it.
I second reading the rules. This will do nothing but help.
Good luck!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 06-01-2013, 21:34
Re: Pneumatic Tanks
Cut the tubes square. If you cut at an angle at all, you're inviting air leaks that may be pretty hard to find.
Unread 06-01-2013, 21:43
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Pneumatic Tanks
We have found that the clear tube is better, as some teams have had other tube, specifically blue, that crushes and pops out of the fittings. Also, plastic air tanks and mini compressor for the win.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 06-01-2013, 22:08
Rishabhgadi's Avatar
Rishabhgadi Rishabhgadi is offline
Alumni, 1255 mentor
FRC #1255 (Blarglefish)
Rishabhgadi is an unknown quantity at this point
Re: Pneumatic Tanks
Pneumatic's are fairly simple. The plastic tanks are the best, and yes make sure the pipe is cut square!! That is so important,make sure you use the right valves on everything and neatness is the key to the tubing or it just gets in the way
Unread 06-01-2013, 22:41
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
Re: Pneumatic Tanks
also the wires from the solenoids dont let the wires get to close together they will begin to melt and cause them to fail it happend to my team in 2011 worst day ever
Unread 07-01-2013, 02:51
Stevel Stevel is offline
Hi dere!
FRC #1676 (Pascack Pi-oneers)
Stevel is an unknown quantity at this point
Re: Pneumatic Tanks
Get acquainted the terminology of pneumatics. I'm assuming most of the team is unacquainted with pneumatics in general. There's a decent amount of new vocab when dealing with pneumatics, but knowing them gives you an advantage when you're reading about part information or looking for help.
Also, be creative! There's lots you can do with a piston if you think hard enough. Take advantage of its length, speed, power, etc.
Unread 16-01-2013, 19:51
Slartibartfest Slartibartfest is offline
FRC #1758
Slartibartfest is an unknown quantity at this point
Re: Pneumatic Tanks
Is there any way to calculate how many times a certain tank can actuate a certain cylinder? Like an equation based on size of piston, force for the piston, size of air tank, pressure of the air tank.
Unread 16-01-2013, 20:09
Nate Laverdure's Avatar
FRC #2363
Re: Pneumatic Tanks
Yes there is! I recommend you read the Pneumatics for Newbies (pdf link) paper on Team 358's excellent Pneumatic Resources page.
Unread 16-01-2013, 21:35
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Pneumatic Tanks
Regarding Teflon tape, you actually do want to be stingy. Just wrap it once around the threads (a couple millimetres beyond a full turn), such that the cut end of the tape is not bunched up by the tightening of the fitting. Leave at least one thread un-taped on the open end of the fitting.
The tape isn't the sealant. Instead, it acts primarily as a lubricant. NPT threads are tapered, and as such, it's the faces of the threads that actually make the seal when tightened properly. (Other types of threaded connections like JIS may not be tapered, but instead depend on other surfaces for sealing.) Excess tape increases the chance that a piece will be squeezed out of the joint, and break off into the fluid stream when pressurized. You don't want pieces of Teflon clogging the tiny valve pilots.
Unread 16-01-2013, 21:51
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: Pneumatic Tanks
Familiarity with the Teflon brand of fluoropolymers has led to the practice of referring to PTFE-based thread seal tape as "Teflon tape". DuPont, owners of the Teflon brand, does not manufacture thread seal tape.
Jim
Unread 16-01-2013, 21:57
Re: Pneumatic Tanks
Does their raw PTFE get used in its manufacture?
Unread 16-01-2013, 23:02
slijin's Avatar
Pockets
AKA: Samuel Lijin
Re: Pneumatic Tanks
From experience, I find that this tends to depend on the quality of the tape itself. The higher quality (i.e. thicker and more durable) it is, the less wraps you'll need; the lower quality it is, the more you'll need.
One thing to remember is to wrap the tape in such a direction that tightening the threads continues to stretch the tape, rather than make it bunch up.
Unread 16-01-2013, 23:23
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Pneumatic Tanks
...You don't want pieces of Teflon clogging the tiny valve pilots.
Nor do you want anything else in those pathways. If the ends of your tubing are open or have spent significant time open, they may already be contaminated. Every time you cut off a piece of tubing for use, you should close off the end of the unused roll to prevent stuff from getting in there. I wince every time I see a piece of open ended tubing in the bottom of the parts tote. Why take chances?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
