Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Unread 06-01-2013, 13:46
ABA's Avatar
ABA ABA is offline
FRC #1153
ABA is an unknown quantity at this point
Collector ideas
What are people's collection ideas?
Unread 06-01-2013, 13:50
TVwazhere's Avatar
TVwazhere TVwazhere is offline
Unregistered User
AKA: TomTom
FRC #0020 (Rocketeers)
Team Role: CAD
TVwazhere can only hope to improve
Re: Collector ideas
I've seen plunger suction designs on youtube.
http://www.youtube.com/watch?v=t8tEbK8S7-8
"Well there's your problem!" -Mythbusters
"It's Dope" -Will.I.Am, Jan 9th, 2011 FIRST Locomotion Kickoff
"Design Thrice, Measure Twice, Cut Once"- Tom Tom
"If your life was a Disney film, then this is the part of the movie where you would break out into song" - Tom Tom
Unread 06-01-2013, 14:27
Darren716's Avatar
Darren716 Darren716 is offline
FRC #4134 (Robo Rams)
Darren716 is an unknown quantity at this point
Re: Collector ideas
I was thinking of having a short ramp with a low incline which would lead directly to a holding area which is connected to our shooting mechanism.
Unread 06-01-2013, 14:43
ttldomination's Avatar
Sunny
Re: Collector ideas
I can't imagine this would be very easy with your driver standing anywhere between 5-45ish feet away from the robot.
Rollers are king.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 06-01-2013, 14:56
DrakusDarkus's Avatar
DrakusDarkus DrakusDarkus is offline
Learning something new, every day!
AKA: Alex S.
FRC #1987 (Broncobots)
DrakusDarkus is an unknown quantity at this point
Re: Collector ideas
Possibly a conveyor belt on a slight incline?
Unread 06-01-2013, 15:04
Chris C. 2410 Chris C. 2410 is offline
FRC #2410
Chris C. 2410 is an unknown quantity at this point
^^If anyone recalls, last year FRC Team 1986, Team Titanium, used a mirror above their acquisition system. That might partially alleviate sight problems. Cameras are also always an option.
The biggest problem I see with any acquisition system is properly orienting the Frisbee. Considering the amount of entropy in regards to how the pieces land, are flying, being shot, etc. , I would see a plunger as a very niche device unless you have a different way to orient it after acquisition.
Personally, I think picking up off the ground is a very specialized approach . If you can build a good drive system, that is one that is quick, agile, and maneuverable, then it might make more sense to be hand fed. This could simplify the robot by eliminating a system, and you also won't have to worry about orientation of the Frisbee as much.
My thoughts...
Unread 06-01-2013, 15:21
AKA: Alex S.
Re: Collector ideas
I agree because Team 1986 is just right next door to our team and we have seen their strategies and other things, etc.
-Alex S.
Programmer on the Broncobots (Team 1987)
Unread 06-01-2013, 16:11
moogboy's Avatar
moogboy moogboy is offline
Wiggling With Experience
AKA: Bubba
FRC #3175
moogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the rough
Re: Collector ideas
This is where my team is leaning. It's also much easier to design something hand fed that will be easier to fix in the event of a catastrophic pyramid fall, which is something that will most assuredly happen this year many times. With a picking up mechanism you have to assume that a robot will land on it at some point and require rebuilding/replacement, which could be a problem at competitions.
I'm Bubba. I make noise, sometimes it comes out as music, and I love robots.
Unread 06-01-2013, 19:24
CJ The Expert's Avatar
CJ The Expert CJ The Expert is offline
Professional Scalawag
AKA: Cassidy
FRC #1359 (Scalawags)
Team Role: Tactician
CJ The Expert is an unknown quantity at this point
Re: Collector ideas
As mentioned above, it seems that very few disks will actually be on the field, unless an inaccurate robot strikes. Therefore, our team decided that a collection system was too difficult to consider building, and that it would not be of much use on the field, especially in consideration to how hard it would be to design/build.
The design we did have before scrapping the whole idea consisted of fans and a funnel, using a "plunger" type idea that could turn on and off. As for orienting the frisbee correctly, a simple post on your delivery/loading system would work. It'd move over the top of the frisbee alright, but if the frisbee was flipped over the wrong way it would catch on the bottom rim and (hopefully) be able to flip it over into the correct orientation.
"Because we can!" - Scalawags motto
Unread 06-01-2013, 19:53
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
Re: Collector ideas
I think that's the main question....
How many frisbees are going to be on the field at any given moment?
The human player stations are so limited in how a frisbee is put on the field that I can't see an "Aim High" scenario where the balls are just ALL OVER the place, despite the relative abundance of frisbees. The frisbees will start to accumalate near the end of the game as the frisbees continue to miss, but I doubt many frisbees will be on the field at any given moment. Until the endgame. Because as we've all seen from Catalyst 2013, the sky will spontaneously start raining frisbees.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
Unread 07-01-2013, 01:32
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Re: Collector ideas
The frisbee shooting that I've seen on youtube so far indicates that they are much more likely to make the 2-3 point goals than the basketballs were last year. So don't expect many white frisbees on the field by the end of a high-scoring match.
I can see where having the ability to collect them is better than not, but it's a rather tricky problem with the tiny bot base and the pyramid floor bump.
Nevertheless, I have no doubt that we'll see many wonderful solutions. I won't be coming up with one myself, though. Not electronic enough.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
