Go to Post I'm pretty sure there is a federal sequester on the bandwidth coming out of LSR. - PayneTrain [more]
Unread 06-01-2013, 15:08
DrakusDarkus's Avatar
DrakusDarkus DrakusDarkus is offline
Learning something new, every day!
AKA: Alex S.
FRC #1987 (Broncobots)
DrakusDarkus is an unknown quantity at this point
Post Question about the rules for Ultimate Ascent
I have read all the rules and I have a question that hopefully someone here can clarify...
Is it legal to pick up your opponent's colored disc and score it in your own goal (non-pyramid)?
(It doesn't say you can't do that)
and could this possibly be a good strategy for defending bots?
Andrew Lawrence
Posts: n/a
Re: Question about the rules for Ultimate Ascent
Is it legal to pick up your opponent's colored disc and score it in your own goal?
There's nothing against it.
Is it a decent strategy? Maybe.
Unread 06-01-2013, 15:09
AKA: Alex S.
Thanks that helped
Unread 06-01-2013, 15:13
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Score them in your own goal all you want, but they're not worth jack.
3.2.4.1 DISC Points
... Additionally, for a DISC to be considered SCORED in an ALLIANCE"S PYRAMID GOAL, it must correspond to the PYRAMID color.
If you score a RED DISC in a BLUE PYRAMID, it's not worth anything (Though you could argue it's worth 5pts that you denied.)
Academic Student (Forever)
Unread 06-01-2013, 15:15
Twest3259 Twest3259 is offline
Murray State University Student
AKA: Travis West
FRC #3843 (RoboRacers)
Twest3259 is an unknown quantity at this point
they'd still count in the one two and three point goals, so essentially you're scoring up to eight points per disc. Because if you made it in the three, and denied them five points.
Unread 06-01-2013, 15:16
AKA: Alex S.
What I meant was take an opposing team's colored disc and score it in your high, low, or middle goal... I think that makes the colored disc count as a white disc that anyone can use unless I interpreted the rules wrong :/
-Alex S.
Programmer on the Broncobots (Team 1987)
Unread 06-01-2013, 15:20
bargy101 bargy101 is offline
AKA: Troy Bargman
FRC #1806 (S.W.A.T.)
Team Role: CAD
bargy101 is an unknown quantity at this point
At the end of the game when the human players can start throwing the discs into the field, do they have to throw over the wall? Or can they throw around the wall?
Unread 06-01-2013, 15:26
AKA: Alex S.
It doesn't specify whether or not you can throw around the wall BUT if it isn't specified in the rules that means that you are able to do that.
Also stay tuned to http://www.usfirst.org/ in case FIRST updates the rules because they might clarify that pretty soon
-Alex S.
Unread 06-01-2013, 15:46
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Something to ask the GDC later, but remember that the netting, which is "made up of three panels that are 10 ft. tall and 14 ft. long", will be there to block throws around the side.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 06-01-2013, 15:47
savage's Avatar
savage savage is offline
FireFighter Paramedic
AKA: Ben White
FRC #1368
savage will become famous soon enough
Send a message via AIM to savage
G17 From looking at the field layout there is no disc return during game play, so I see where you guys are going with this. But per Cal trans Question you are violating G17 and this is a foul.
Unread 06-01-2013, 15:53
cosmicexplorer cosmicexplorer is offline
FRC #1389
cosmicexplorer is an unknown quantity at this point
Ok, but this isn't asking about putting discs in the opponent's pyramid goal. The question is if the opponent tried to put discs in their pyramid goal and missed so the frisbees are on the floor, could you pick those frisbees up and toss them in your own high/mid/low goals for points?
Unread 06-01-2013, 16:07
GaryVoshol's Avatar
Cogito ergo arbitro
There's nothing in the rules to limit what you do with your opponent's color of discs. They won't count in your pyramid goal, but they should count in one of your other goals - barring a different interpretation from Q&A.
Regarding throwing in the discs, look at the rule again:
Originally Posted by G35
DISCS may be fed onto the FIELD only under the following circumstances:
A. during TELEOP through the FEEDER SLOTS and
B. during the last thirty (30) seconds of TELEOP over the FEEDER STATIONS.
See that word "only" there? Round the wall is not over the wall, so it would not be permitted.
(since 2004)
Unread 06-01-2013, 16:12
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Per the definition of SCORED:
SCORED: A DISC is considered SCORED in an ALLIANCE’S GOAL if any part of the DISC has crossed through the opening of the GOAL, is in the GOAL at the end of the MATCH, and the DISC is not in contact with any ROBOT from that ALLIANCE. Additionally, for a DISC to be considered SCORED in an ALLIANCE’S PYRAMID GOAL, it must correspond to the PYRAMID color.
Since disc colour only must correspond to the pyramid, I think it would be safe to assume that you can score the other alliance's coloured discs in your own non-pyramid goal.
Unread 06-01-2013, 16:14
slijin's Avatar
Pockets
AKA: Samuel Lijin
In short: yes.
Chimera0x694's Avatar
Chimera0x694 Chimera0x694 is offline
AKA: Kelly Malone
FRC #1684 (The Chimeras)
Chimera0x694 is just really niceChimera0x694 is just really niceChimera0x694 is just really niceChimera0x694 is just really nice
Exclamation Re: Question about the rules for Ultimate Ascent
You MUST throw OVER the wall. We had one of the Michigan FRC advisers elaborate. You are not allowed to throw discs to the side of the walls.
Hope this helped!
"How do you pronounce your name?"
We get asked this question a lot. Or, We are called "chi-mare-ahs" Or, "chI-mare-ahs"
To set the record straight, It's pronounced "kI-mare-ahs"
2011-
Ranked 172nd in the state of Michigan
2012-
Ranked 24th in the state of Michigan
Kettering University District-Quality Award
