#16
Re: Question about the rules for Ultimate Ascent
Out of curiosity, do you remember who this person was? |
#17
If you wanted to throw around the wall, you may be in violation of these 2.
G36 Quote:
I don't mean to Hijack this thread but it does have a very broad title so I figured I'd post my question here rather than make a new thread. According to R03:
#19
I'd expect interpretation/clarification on Wednesday, but to inject my useless opinion, it doesn't seem likely enough to happen nor enough of an anti-competitive strategy to warrant a change.
#20
"PLAYING CONFIGURATION: The physical configuration and orientation of the ROBOT while playing the game (i.e. after the MATCH has started, and the ROBOT has deployed mechanisms, moved away from the starting location, and/or interacted with the field, GAME PIECES, or other ROBOTS). This configuration is dynamic, and may change multiple times during the course of a single MATCH." As soon as auton begins and your robot moves in any way, it is then in playing configuration for the remainder of the match, including when climbing. |
#21
Well it seems I should just change the title of this thread to Questions and Answers about the rules for Ultimate Ascent (It seems to have evolved)
#22
Hopefully no robots fall down from level 3 this year (that would be catostrophic) |
#24
Also about the colored discs, where are they located during the match? And do you have to wait until the end game to distribute them, or can you throughout the match?
#25
Colored discs are located behind the corresponding Alliance wall. The has, so far, been no restriction on when the discs can be introduced to the field, though there are restrictions as far as the method of introduction goes.
#26
New question: Would it be a good strategy to backup so that your robot is touching the pyramid and then shoot goals so that other robots cant touch you?
#27
I have a question: Does anyone know if you allowed to extend part of a robot into the 1 pt. goals?
G12 says "Robots may not contact anything outside the FIELD." The penalty is being disabled, so anything that risks this is pretty much out of the question. Arena rule 2.2.1 says that "The FIELD for ULTIMATE ASCENT is a 27 by 54 ft. carpeted area, bounded by ALLIANCE WALLS, FEEDER STATIONS, LOW GOALS, and GUARDRAILS." So would it be okay to extend into the goal, as long as you don't touch anything? Or is the back of the low goal the boundary, and so you have free reign inside the goal? |
