Go to Post P.S. No matter what happens a build season, you will always have memories. - Briansmithtown [more]
Unread 06-01-2013, 19:25
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Image Display on Smart DashBoard.
Hello. I am trying to use the smart dashboard to display raw camera data and vision tracking code. I have a question about doing so: Is there a built in widget that would do so for me or would i have to write my own code?
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 06-01-2013, 19:45
Re: Image Display on Smart DashBoard.
I don't see any instructions for it yet, but last year you needed to use the installer to get the image component and I see a new installer has been posted here: http://firstforge.wpi.edu/sf/frs/do/.../frs.installer
Last year's installed the SmartDashboard to it's own directory in Program Files and added a "camera" or similar option to the "Add" menu item in the dashboard.
Unread 06-01-2013, 22:11
Hypnotoad's Avatar
Ok. I did the instllation and it still didn't have the option when I ran the driver station. It appears that it does not change the dashboard that it targets when you run the setup.exe, so I have to run the jar file manually. I did exactly that and added a camera. I got a block saying no connection and ensured that the ip was correct. Due to the properties menu including a reference the the camera ip itself, I will temporarily assume that the code ran automatically when you added a camera widget.
My question is: was I correct in my assumption? Do I have to write any code on the robot to send the camera data? Do I have to maybe do some kind of setup on the camera to allow smartdashboard to access it?
Sorry for the long post.
My teeth are false.
Unread 06-01-2013, 22:17
You need to enable anonymous access on the camera in addition to the "normal" setup. See this page for details: http://wpilib.screenstepslive.com/s/...an-axis-camera
Unread 10-01-2013, 01:28
Hypnotoad's Avatar
Sorry for the late reply. I did that and I still had no connection. I then decided to run he exe instead of the jar and it magically worked. Don't know what happened but it works. Thanks for the help.
My teeth are false.
