Go to Post Be not afraid, go forth and multiply. - Pat Major [more]
Unread 06-01-2013, 19:26
4AngryNutjobs's Avatar
4AngryNutjobs 4AngryNutjobs is offline
FRC #3859
4AngryNutjobs is an unknown quantity at this point
Does 54" include bumpers?
Our team was wondering about the width of the robot and we were wondering if the bumpers would be included when they put us in the 54" cylinder. Its rule G23 in the FRC Manual.
Unread 06-01-2013, 19:34
bluecraney bluecraney is offline
FRC #0885 (The Green Team)
bluecraney is an unknown quantity at this point
Re: Does 54" include bumpers?
I was wondering this my self but it seems the bumpers don't count as "part of the robot" so it don't have to be in area and weight requirements if i am wroung please correct me
Unread 06-01-2013, 19:40
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
R5: For the purposes of determining compliance with the weight and volume limitations, the items listed below are not included in the weight assessment:
A. the ROBOT battery and its associated half of the Anderson cable quick connect/disconnect pair (including no more than 12 in. of cable per leg, the associated cable lugs, connecting bolts, and insulation) and
B. BUMPERS (including BUMPER covers, if appropriate).
Emphasis mine. 54" diameter cylinder isn't exactly volume, but I would interpret the rule as saying that bumpers don't count toward the 54". This is a question for the Q&A, though.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 06-01-2013, 19:54
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
Since this rule is in the Game manual and not the Robot manual, I would interpret it as including the bumpers. Why, because game rules are primary enforced by the referees who don't see the robots without bumpers. I have seen the inspection people make sure your robot can't extend mechanisms outside this dimension, but once again this rule is meant for game play not inspections.
But once again this is just my interpretation.
Unread 06-01-2013, 20:50
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Well, consider R3:
Originally Posted by R03 B
PLAYING CONFIGURATION horizontal dimensions may never exceed a 54 in. diameter vertical cylinder (see G23)
And the definition of PLAYING CONFIGURATION:
Originally Posted by Glossary
PLAYING CONFIGURATION: The physical configuration and orientation of the ROBOT while playing the game (i.e. after the MATCH has started, and the ROBOT has deployed mechanisms, moved away from the starting location, and/or interacted with the field, GAME PIECES, or other ROBOTS). This configuration is dynamic, and may change multiple times during the course of a single MATCH.
These lead me to believe that bumpers are included in the 54" (even though G23 doesn't mention bumpers anywhere). And since this specifies the robot's condition during a match, when bumpers are mandatory, I'd guess they're included. Either way, this is a great question for the Q&A
Unread 06-01-2013, 20:51
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Does 54" include bumpers?
Definitely a question for the GDC. There is ambiguity in R05 where one paragraph refers to weight and volume, and the next only weight with reference to bumper excusion.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 06-01-2013, 22:08
ttldomination's Avatar
Sunny
I mean, this seems clear enough...
Not sure why others are trying to lawyer the rules further, but I suppose the GDC will settle all.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 06-01-2013, 22:27
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Two possibilities:
1. bumpers part of the 54" limit.
2. not
difference between case 1 and 2 is about 3" (or less) of extra extension outside frame perimeter for some mechanism. Glad and scared to see this degree of precision design during week 0.
I think you should make your machine work and then worry about the 54". BTW are you going to make a hoop for testing this?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 28-01-2013, 12:44
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Has this been definitively answered one way or the other?
I could really use 3" right now...
Joe J
Team #88, TJ2
Unread 28-01-2013, 12:50
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Unfortunately you wont get the 3 inches. It has been answered, and the bumpers count towards the limit.
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 28-01-2013, 13:01
Littleboy Littleboy is offline
FF: The Yellow Alliance (TYA)
Littleboy has a spectacular aura aboutLittleboy has a spectacular aura aboutLittleboy has a spectacular aura about
It is answered in Q&A 44. Yes, they do count.
https://frc-qa.usfirst.org/Question/...-r05-ambiguous
Unread 28-01-2013, 13:03
AKA: Dr. Joe
FRC #0088 (TJ2)
Clear answer. I can wish for another one but I will take clarity anyday.
Thanks.
Joe J.
Team #88, TJ2
