Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 06-01-2013, 21:13
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Climbing Mechanism Ideas
Did you think of a better way to get around the joints than the 3 actuated hooks we thought up?
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
  #62   Spotlight this post!
Unread 06-01-2013, 21:18
escime's Avatar
escime escime is offline
Earl Scime
FRC #2614 (MARS)
escime is a name known to allescime is a name known to allescime is a name known to allescime is a name known to allescime is a name known to allescime is a name known to all
Responding to dheerm here. Maybe I am missing something with this climber idea. But when you start the climb and leave the ground you cannot be touching that second horizontal rung. So doesn't your robot just swing outwards and become vertical again? We've been toying with ideas along this line for two days and cannot see how to reliably keep the bot from kicking back out vertical once you leave the ground (and therefore touch the ground again - which prevents you from grabbing that second rung).
  #63   Spotlight this post!
Unread 06-01-2013, 21:19
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
with the inchworm idea, you have two separate but identical grabbers at the bottom of the robot, that the robot can sit back on and hang while the puling arm repositions itself. when the upper grabber hits the knuckle, it retracts, and the robot rests on the lower grabber. Then, when the lower grabber hits the knuckle, the upper one comes back, and the lower one retracts. We also "sit" on these, similar to the way the sliding, pump handle clamps prevent from opening, while the raising arm repositions itself.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
  #64   Spotlight this post!
Unread 06-01-2013, 21:20
moogboy's Avatar
moogboy moogboy is offline
Wiggling With Experience
AKA: Bubba
FRC #3175
moogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the rough
I'm thinking that a groove down the center of the robot with a belt on each side with floating sprockets at the front and back will be a good way of keeping the robot close to the pole. I've detailed elsewhere in this thread more of what would be on each belt, but a floating sprocket could be considerably helpful.
I'm Bubba. I make noise, sometimes it comes out as music, and I love robots.
  #65   Spotlight this post!
Unread 06-01-2013, 21:21
pmangels17's Avatar
AKA: Paul Mangels
Either style works. The best way to climb the outside is probably on the corners. However, you must prevent yourself from spinning around on the pole.
  #66   Spotlight this post!
Unread 06-01-2013, 21:28
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
What about using the rungs? A robot with two extendable arms and hooks, each on a rotating "shoulder" joint? Think monkey bars.
  #67   Spotlight this post!
Unread 06-01-2013, 21:29
pmangels17's Avatar
AKA: Paul Mangels
We were thinking skis on the sides of the corner climber, that ride on the horizontals.
  #68   Spotlight this post!
Unread 06-01-2013, 21:36
AKA: Jesse Gibson
Team Role: CAD
How would you hold the robot on as it's climbing?
2011 - Logomotion
  #69   Spotlight this post!
Unread 06-01-2013, 21:38
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Here's an idea I happened to think of:
Use two vertical and sliding rails, the could be pivoted out at the same angle as the pyramid (either 68 degrees or 60 degrees). The ends of the rails would have a hook that was spring loaded and could collapse inward when pushed from the top, but hold rigid when pushed from below. Similar to rung lock mechanism on an extension ladder:
To start, one would drive to the pyramid, swing out the rails, and raise one rail so the hook would ratchet into the rail when it hit the rung, slide past, pop out, and grasp the rung. Then that rail would be retracted back, lifting the robot base. This process would be repeated for the second rail to reach the second rung, and then again with the first rail to reach the third rung.
A ratchet/anti-backdrive system would be in the drive for the rails, to reduce load on the motors and to keep the robot up when the match was over.
Just a thought I had. I haven't been on a robot design committee for a couple years but my mind still is in the "habit".
  #70   Spotlight this post!
Unread 06-01-2013, 21:40
pmangels17's Avatar
AKA: Paul Mangels
You could use a ratchet system, or you could use a worm drive, which could be reversed if need be. That is what out design requires. Or helical gears.
  #71   Spotlight this post!
Unread 06-01-2013, 21:41
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Originally Posted by moogboy View Post
One of our mentors came up with a non-wheeled design. a 50 pound, 16x16x16 cube that would do nothing except climb to the third level. Really, you wouldn't even need drivers. Someone could take that idea of a non-wheeled robot and ask really nicely for other robots to give them the alliance colored frisbees and have a really simple dumping mechanism to get another 20 points.
Did he have a plan for attaching bumpers to it? I mean one that doesn't interfere with the climbing. Maybe once climbing has begun, the bumpers could be dangled from a cord.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #72   Spotlight this post!
Unread 06-01-2013, 21:50
moogboy's Avatar
AKA: Bubba
FRC #3175
To limit post size I won't go into all of the details again, but early on (like page one or two of this thread) I described it a little better and linked to a Youtube video that shows his inspiration. Essentially though he did not need to worry because all of the climbing mechanism was underneath the robot and the bumpers could be mounted above it.
  #73   Spotlight this post!
Unread 06-01-2013, 22:07
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Originally Posted by tickspe15 View Post
Is there any rule against using electromagnets to grip the pyramid.
No, but I'd be concerned about
  1. Whether or not the battery has enough juice to sustain such a powerful enough magnet
  2. What such a powerful magnet would do to the electronics
  3. Whether inspectors would consider such a device to be safe
Not to mention that all outputs are disabled when the match ends and I think such a device is required to be controlled by the cRIO.
  #74   Spotlight this post!
Unread 06-01-2013, 22:08
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by mrnoble View Post
... Is there any precedent in FIRST for non-wheeled bots?
Our team did tank treads for Breakaway (2010). Powerful, couldn't be pushed, and always went over the bumps. But not very fast.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #75   Spotlight this post!
Unread 06-01-2013, 22:29
dheerm's Avatar
dheerm dheerm is offline
Drive Team and Head Programmer
AKA: Dheer Mirchandani
FRC #0224 (The Tribe)
dheerm will become famous soon enough
I didn't think of that. Even if we used a top heavy robot, it would just keep spinning till it fell. Unless maybe this robot was designed so perfectly that the conveyor belt with hooks on it immediately grabbed the second rung the moment the robot was lifted off the ground then maybe it could work.
"All you need is duct tape and a dream"
Team 224:
District Champions @TCNJ w/ Team 56 and Team 293
8th alliance captain at MAR championships w/ (take a guess) , Team 56 and Team 293.
www.team224.com
