Go to Post Ironically, I think the best testament to the program [Dean Kamen] founded and his ideals wouldn't be if he won a Nobel Prize. It would be if you did. - Kevin Sevcik [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 06-01-2013, 22:51
pfreivald's Avatar
AKA: Patrick Freivald
Re: Climbing Mechanism Ideas
Originally Posted by Cal578 View Post
Our team did tank treads for Breakaway (2010). Powerful, couldn't be pushed, and always went over the bumps. But not very fast.
Treads aren't something I'd advise unless you've prototyped in the off-season.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #77   Spotlight this post!
Unread 06-01-2013, 22:55
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I can only think of two approaches that will work and meet the requirements of the rules (or at least their spirit, as I read them; QA will need to clarify some things on the 9th). Approach #1: a caterpillar, either outside or inside the corner. Approach #2: a human/ape approach, with at least two grasping and releasing appendages. You can't balance on two rungs, as you won't be able to touch three zones at a time.
  #78   Spotlight this post!
Unread 06-01-2013, 23:08
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
Team Role: Electrical
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
Originally Posted by cgmv123 View Post
Not to mention that all outputs are disabled when the match ends and I think such a device is required to be controlled by the cRIO.
Would it be against the rules to use a spike relay, a NOT gate, and an additional relay on your electromagnet? I'm not saying that an electromagnet would be feasible, I'm just saying that your robot (if designed well) would not fall at the end of a match.
  #79   Spotlight this post!
Unread 06-01-2013, 23:44
neaanopri neaanopri is offline
FRC #1389
neaanopri is an unknown quantity at this point
I thought of a third approach.
If you had a hooked conveyor belt on a pivot in the body, which was on rails, you could lift yourself from the ground, tilt the pivot to grasp the second rung, then elevate yourself above the first rung and hang from the second. Repeat to hang from the third rung.
Here's a picture: http://imgur.com/w37qr
It would then repeat this to get up to the third ring.
Pros:- Doesn't take as many motors
- Robot does not have to be specifically designed to lift.
Cons:-Takes a long time
-Requires a functioning hooked conveyor that can lift the whole robot
  #80   Spotlight this post!
Unread 07-01-2013, 00:32
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Originally Posted by tickspe15 View Post
Is there any rule against using electromagnets to grip the pyramid.
Yes, by R32, electric solenoids may not exceed 10 watts. The rule refers to "electrical solenoid actuators", but R52 simply refers to "electric solenoids". Also, in previous years electromagnets have been lumped in with motors/electric actuators and I do not see that changing this year.
Jason
  #81   Spotlight this post!
Unread 07-01-2013, 01:24
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Yes, that would be illegal. You cannot have custom components between the MC and the motor/electrical actuators. The only thing that you could possibly put there is a cap as a filter. Also, the second relay would need power, which restricts the relay to be a spike. Additionally, the magnet probably would fail R32.
  #82   Spotlight this post!
Unread 07-01-2013, 01:35
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Any teams had any luck prototyping "minibot climber" types? I'm talking about something that rides up the diagonals of the pyramids on wheels, hanging on somehow.
-Plutarch
  #83   Spotlight this post!
Unread 07-01-2013, 02:37
Joon Park's Avatar
Joon Park Joon Park is offline
Joony13
FRC #0639 (Code Red Robotics)
Team Role: CAD
Joon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud of
We've actually done tank treads for the past four years that we've gotten better at treads than wheels.
Team 639: Code Red Robotics
2013 Robot: The Red Raptor
2013 Archimedes Division
2013 Buckeye Regional Winner
2013 Buckeye Spirit Award
2013 FLR Spirit Award
2012 Newton Division Finalist
2012 FLR Semi-Finalist, Engineering Inspiration Award
2012 DC Quarter-Finalist, Industrial Design Award
2011 FLR Quarter-Finalist
2011 Boston Quarter-Finalist, Imagery Award
2010 FLR Quarter-Finalist, Innovation in Control Award
2010 Philladelphia Semi-Finalist, Gracious Professionalism Award
  #84   Spotlight this post!
Unread 07-01-2013, 03:38
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
For this, I've been thinking of having an articulated 1717 2010-esque lifter that will be able to traverse the corners. Have a latching system on the top, and drive wheels at the bottom. By any chance, does anybody have close up pics of their latching mechanism from that year?
I see that they posted pics of their bot here: http://www.chiefdelphi.com/media/photos/35361
But the only pic that is broken is the one for the latching.
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
  #85   Spotlight this post!
Unread 07-01-2013, 05:59
President, VEX Robotics, Inc.
Originally Posted by moogboy View Post
One of our mentors came up with a non-wheeled design. a 50 pound, 16x16x16 cube that would do nothing except climb to the third level. Really, you wouldn't even need drivers. Someone could take that idea of a non-wheeled robot and ask really nicely for other robots to give them the alliance colored frisbees and have a really simple dumping mechanism to get another 20 points.
We would definitely pick this robot in the first round if it could get 30 points every match. If it could score in auton, that it is a no brainier.
At the risk of looking like an idiot like last year (thanks HOT), the 30 point hang will be able to be accomplished by less than 20 teams in all of FRC.
So if your robot can get 30 points from the hang, they are a keeper for a great partner to frisbee shooting robots.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #86   Spotlight this post!
Unread 07-01-2013, 06:22
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
If they can do that and a little more they might be picking you
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
  #87   Spotlight this post!
Unread 07-01-2013, 07:39
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
It was great for bending omniwheels too, let's not forget that
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
  #88   Spotlight this post!
Unread 07-01-2013, 08:25
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is an unknown quantity at this point
Here is an interesting idea: http://youtu.be/zkpH1BjD6Wc
  #89   Spotlight this post!
Unread 07-01-2013, 09:31
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
A little more towards the insane side of the spectrum...
I did a quick calculation comparing kinetic and potential energy. The numbers actually make this feasible.
Remember “Back to the Future”? If you put a 30 inch vertical hook on the back of your robot, and drove at full speed under the tower, the hook would catch on the lowest bar, and the robot would flip up high enough for you to catch the second bar. Then you release the lower bar hook and score 20 points. Unless the tower or the robot comes apart at impact…
You need a very fast robot and the starting height of the robot CG should be as high as possible. We think it would be ruled "unsafe" for competition, but it would be fun to prototype...
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #90   Spotlight this post!
Unread 07-01-2013, 09:47
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
That has come up, and It would be amazing to see. But I feel the "floor protector" would keep from that design from successfully working. Although I think you already came to that conclusion
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
