Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 06-01-2013, 22:56
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Getting OpenCV and JavaCV working on Windows
Hi all,
I've been trying to work on vision processing on the driverstation, but I can't seem to get OpenCV working correctly. I have a test file that should and display an image with OpenCV:
import com.googlecode.javacv.CanvasFrame;
import com.googlecode.javacv.cpp.opencv_core.IplImage;
import static com.googlecode.javacv.cpp.opencv_highgui.cvLoadImage;
public class TestClass {
    public static void main(String[] args) {
        //Load image img1 as IplImage
        final IplImage image = cvLoadImage("img1.png");
        final CanvasFrame canvas = new CanvasFrame("Demo");
        canvas.showImage(image);
        canvas.setDefaultCloseOperation(javax.swing.JFrame.EXIT_ON_CLOSE);
But I get an UnsatisfiedLinkError with the message "no jniopencv_core in java.library.path" when I run it. I have a feeling that OpenCV isn't installed correctly based on some research I've done. Are there any good tutorials for getting JavaCV working with the SmartDashboard?
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 07-01-2013, 10:12
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
Re: Getting OpenCV and JavaCV working on Windows
Hi Sam,
Check to see that the JVM that you are running in 32-bit (not 64-bit) as the native libraries are 32-bit and must run in a 32-bit JVM. You can check this by running "java -version" from the command line.
