Go to Post I keep on accidently seeing (and pronouncing) it as Chef Deli. - JJG13 [more]
Unread 06-01-2013, 22:57
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Simple CAD help
I am a freshman who is just learning Inventor, and I was wondering about
how to make in CAD a funnel with the tube and the floating circle.
This is what I have so far:
Unread 06-01-2013, 23:00
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Simple CAD help
Try using the loft option. If it is anything like the lofted flang option available for working with sheetmetal, then it should do what you want. I'll experiment a little though, in case that doesn't work.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 06-01-2013, 23:03
Michael Hill's Avatar
Re: Simple CAD help
Alternatively, you can draw up the profile and just rotate it Either way is just fine.
Unread 06-01-2013, 23:05
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Simple CAD help
It is simplest to use a revolve for that.
Name:	Revolve Funnel.jpg
Draw a sketch like that and then do a revolve. Select the line on the bottom as your axis and you'll get a funnel shape.
Re: Simple CAD help
I tried loft earlier, but it came out like this, where i want it hollowed out.
Unread 06-01-2013, 23:06
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
Re: Simple CAD help
That is an option, though a loft of that nature with the existing geometry shown will give a solid cone on the end of the tube.
If however, you want your cone to be hollow as well, you can add an addtional circle in the middle of the existing one, in hopes that it creates the wall. If that does not work, it would not take long to do a Revolve Operation. In that case, simply draw and dimension the upper half of the wanted section view, draw the centerline, and apply the revolve feature.
I was just teaching some of our kids how to do those two different strategies today actually! There are many youtube videos of Inventor and SolidWorks on youtube, and both may be helpful due to the similar nature of the two programs. If those do not solve your questions in a timely manner you can always PM me or post again!
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 06-01-2013, 23:18
Re: Simple CAD help
Thank you for the help everyone!
Unread 07-01-2013, 11:44
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Simple CAD help
I agree with the sketch > revolve work flow. Also, to hollow out the part, use the Loft command. Loft is high up on my coolest commands in Inventor list!
If you need further help, post me the dimensions and I can assist, although there is always a lot of great help from other teams on this forum.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 07-01-2013, 15:00
Re: Simple CAD help
Going further, The same part, when added to a full design, refuses to go to where I want it to.
This is where I put it, and then I save it:
Then when I save it, and then open up after closing it again, it just goes back to the original placement:
Unread 07-01-2013, 15:07
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: Simple CAD help
Are you fully constraining it in place?
Unread 07-01-2013, 15:17
Re: Simple CAD help
Oh, that must be it. But it does not explain why a few other pieces are staying in place after a save...
Unread 07-01-2013, 16:31
TVwazhere's Avatar
TVwazhere TVwazhere is offline
Unregistered User
AKA: TomTom
FRC #0020 (Rocketeers)
Team Role: CAD
TVwazhere can only hope to improve
Re: Simple CAD help
Depending on the constraint, you need 1 to 3 constraints to secure one part to another.
Could you zoom in on the part and also open up any constraints you have on the part thats moving?
"Well there's your problem!" -Mythbusters
"It's Dope" -Will.I.Am, Jan 9th, 2011 FIRST Locomotion Kickoff
"Design Thrice, Measure Twice, Cut Once"- Tom Tom
"If your life was a Disney film, then this is the part of the movie where you would break out into song" - Tom Tom
Unread 07-01-2013, 23:50
yash101 yash101 is offline
AKA: null
Smile Re: Simple CAD help
Just do a loft then shell the whole thing.
