Go to Post Tragedies happened. We've learned from them, as individuals, as teams, as a community. - Taylor [more]
Unread 06-01-2013, 23:13
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Press fitting
Originally Posted by akoscielski3 View Post
Sheet metal and the wall of your tubing has little difference when you are press fitting a bearing into it. you should be able to use the same sizes as that thread states.
Generally for FRC usage a thou under is enough.
The bigger issue is can you actually machine to that kind of tolerance?
A reamer would do it perfectly every time however just using say an endmill on a CNC machine you may be a few thou off due to tool wear causing a press fit to turn into a non fit.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
