| Thread Tools |
Rating:
Display Modes |
#31
Re: How to pick up a frisbee
Could a robot block the path to the feeder station by just sitting there?
#32
But, as is popular, "assuming makes an $@#$@#$@# out of you and me". At least for my team, this warrants a couple of runs through our prototypes. - Sunny G. |
#33
I forget which rule, but your robot can't purposefully block an area of field and then they aren't allowed to touch your robot when they are at the feeder station.
#34
Yes, I also recall that rule. It states that a robot cannot intentionally block and prevent the "flow" of the match. But this rule has been in the manual for quite some time, as I remember. Like in Logomotion, bots patrolled the middle of the field and blocked bots from crossing. I don't remember penalties every being called against this. The only defensive penalties I've seen is contact in a protected zone (which would be the feeder station and when a bot is touching the pyramid in this case). So this leads me to believe, either the refs aren't calling these penalties, or this isn't considered blocking the "flow" of the match. And if that isn't blocking the flow, I don't know what would be considered so.
#36
I get the feeling that this is going to be the biggest argument of the build season.
I personally think that our second-year team is better off not trying to get them off the floor, and instead concentrating our efforts on building a feeder-fed bot in three weeks and practicing with it for the next three weeks. That will allow us to be consistent scorers, so we won't be littering the field with frisbees. It will also get us ranked highly in the qual matches, which is where we want to be. |
#37
Violation: TECHNICAL FOUL |
#38
So, it would be a penalty to, say, park in front of the opposing alliance's feeder station. But it's ok to prevent them from crossing the field to get to their feeder station. Is this correct?
#39
The key parts from G25) ROBOTS on the same ALLIANCE may not blockade the FIELD in an attempt to stop the flow of the MATCH. This rule has no effect on individual ROBOT-ROBOT interaction are "ROBOTS" plural and "no effect on individual ROBOT-ROBOT interaction." |
#40
Tape... :-D
#42
Addressing two points in this thread:
1. A "Hammer" or "Tomahawk" is thrown exactly as the name would suggest, over the head. This is not the direction a disc would travel in a flat path. The purpose of this type of throw is to travel at a greater height than distance. This is why human players would use this to throw over the alliance wall. Robots could possibly throw this way. As every new year comes, some team somewhere will make it happen if they try hard enough. 2. The rules state that you may block people at any point as long as they are not touching their pyramid, their safe zone next to the feeder station, and you do not pin them for more than 5 seconds. Although it would be against the spirit of FIRST and stopping the flow of the game, it is legal at this point in the season before any rule updates to block the feeder station. This is something that if seen at a competition, would most likely be changed for the rest of the season. |
#43
The main reason I see for bothering with a floor pickup system, is for the advantage in autonomous. Last year it was a game decider for some teams that could get extra game pieces to score in autonomous.
#44
I'm not sure that Autonomous would be the only advantage. Even if all the 'bots were able to score at an 80% average, that could leave ~25 game pieces on the floor if they stayed on the Field.
#45
Autonomous would not be the only advantage, but to me it appears to be the main advantage. Thinking of how many game pieces can be scored during a match, it's going to be a challenge for an alliance to use up all 45 in two minutes
