Go to Post According to a recent study, 63% of teams admit they are behind. The other 37% are lying. - nitneylion452 [more]
Go Back   Chief Delphi > Competition > FRC Game Design
Unread 07-01-2013, 02:09
Avihu Avihu is offline
FRC #4661
Avihu is an unknown quantity at this point
FRC arena & pyramid sizes
hello there, I need please to have the Zises of the arena, the feeder station, the pyramid.. basicly all of the sizes.. can someone plz give me a summary of the zises? we need to start build it quickly
Unread 07-01-2013, 02:13
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: FRC arena & pyramid sizes
All of the files that are needed to build a team version of the field elements are all located on the FIRST website. www.usfirst.org
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 07-01-2013, 03:32
399thegeneral's Avatar
399thegeneral 399thegeneral is offline
AKA: Jackie
FRC #0973 (The Greybots)
399thegeneral will become famous soon enough
http://www.usfirst.org/sites/default...m_Drawings.pdf
www.greybots.com
Unread 08-01-2013, 02:01
izharsy izharsy is offline
izhar
AKA: izhar
FRC #1690 (orbit1690)
izharsy is an unknown quantity at this point
the manual talks about 1.5" iron pipe while the instructions talks about 1.25"...
what is the corect size?
Unread 08-01-2013, 10:19
The inexpensive "team drawings" document talks about 1.25 pipe. The dimensions for that pipe are 1.38" inner diameter and 1.66" outer diameter. It's actually slightly thicker than the 1.5" steel tube in the official field drawings.
Would it surprise you to know that a 2x4 piece of wood is not 2" by 4"? If you're concerned about the true size, check the dimensions, not the label.
Unread 08-01-2013, 11:04
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
To add onto this, I haven't been able to tell what the exact height of the TOP of each rung is (30"? 30.75"?). So we're going to add in some room for error in the design. This is generally a good idea since the fields may all go through some tiny deformations (+/- a few eights of an inch) from Regional to Regional depending on if robots fall, slam, or otherwise bang into the pyramid.
GitHub
