Go to Post Come on guys....what else could we expect.....its Wildstang!!! - Kyle Love [more]
Unread 07-01-2013, 08:26
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Javadocs?
Is there no support for Javadocs in the WPILib this year? I looked in a few of the source files and saw no Javadoc formatted comments.
Unread 07-01-2013, 08:42
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Re: Javadocs?
I looked through a few (RobotDrive Jaguar Victor and DoubleSolenoid) and they all had plenty of JavaDoc comments. Which particular classes did you look at?
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 07-01-2013, 09:04
AKA: Jim O'Malley
Re: Javadocs?
Bizarre. I think I started with Accelerometer and looked at the first few and then Gyro. I'll look again tonight, maybe I was just too sleepy. Thanks for the reply.
Unread 07-01-2013, 09:05
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Javadocs?
The Javadocs are still there. On Windows they are in
C:/Users/<username>/sunspotfrcsdk/doc/javadoc/index.html
Or wherever your sunspotfrcsdk is.
You can even attach Javadoc toi the WPILib classes in netbeans by clicking "Attach Javadoc" when the "No Javadoc Available" stuff appears on a tooltip by pointing to .../sunspotfrcsdk/doc/javadoc .
Unread 07-01-2013, 11:32
gixxy's Avatar
Re: Javadocs?
Also, the WPIlib source may not be attached to the library in Netbeans.
If when you view the source you see lots of sections saying "compiled code" then you will also see a button to "Attach Source". The source will be in: /sunspotfrcsdk/lib/wpilib.src.zip I believe. Just attach the zip file, you don't need to extract it.
Unread 07-01-2013, 12:25
AKA: Jim O'Malley
Re: Javadocs?
Not to get off topic, but I did unzip them. In past years I've needed to modify and rebuild, and I figured it would help compile time.
Unread 08-01-2013, 12:02
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
AsianRookie is an unknown quantity at this point
Re: Javadocs?
I generated the doc. Attachment is below.
Unread 08-01-2013, 14:00
AKA: Jim O'Malley
Re: Javadocs?
Everthing is fine (except my brain ).
Code Folds -> Expand All JavaDocs
made everything appear.
Unread 02-02-2013, 15:25
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: Javadocs?
so we have been having this issue as well ( we are trying to trouble shoot some things with the robot and none of the java docs are loaded)
we have gone in and loaded the java docs from the user sunsp/docs/javadocs in the tools->java platforms section , and from the .zip on this page, but Netbeans still doesn't show the java docs.
we have attempted attaching the javadocs from each error ( with ctl +F1), still no good ( BTW it asks for wiplib and sqwak attached to either the local or the .zip still shows an empty javadocs)
we have verified that the local location html files are populated ( and work). we have verified that the supplied zip html files are populated ( and work).
this is on all 4 of our computers 2 Windows 7 and 2 Windows XP
any additional info or help would be greatly appreciated
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 02-02-2013, 23:57
AKA: Jim O'Malley
Re: Javadocs?
Did you follow Big J's advice above (post #4)? It worked for me.
