Re: create new robot project fails.
So far I've tried several sugegstions but still with no avail.
Since the issues seem to be with some of the Rock Robotics routines, I have tried a Mass Compile of the folder. This process produced a large number of errors which are listed here: https://decibel.ni.com/content/thread/15786?tstart=0 Scroll to fourth post. I generated a MAX Log and uploaded it to provide additional information. Next, in the event that there had been a bad install, I deleted the entire Rock Robotics folder and did a Repair install of the NI_LabVIEW Update. Still the same problem. I went and looked at one of the VIs listed as bad in the mass compile: C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\Rock Robotics\SystemInterfaces\AnalogTrigger\FPGA_Analo gTriggerReadLowerLimit.vi It did in fact have several broken wires. (see snipit at end of thread on NI forum listed above) It's feels like some VIs that interact with certain portions of the FPGA have broken interfaces. Could there be a problem with the FPGA library, or perhaps my RT environment is not working? Just clutching straws. I'm dreading a full LabVIEW un-install/re-install because it takes so darn long. (even with a top of the line machine). Phil. Last edited by PhilBot : 07-01-2013 at 08:41. Reason: Typos |
