Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 07-01-2013, 11:57
ROBOGIRL2781 ROBOGIRL2781 is offline
FRC #2781
ROBOGIRL2781 is an unknown quantity at this point
Disc Throwing
Are there any exceptions as to where you can throw discs from?
Unread 07-01-2013, 11:58
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Disc Throwing
As of the Kickoff revision of the rules, no. Legally speaking. Practically speaking? That's a whole other issue.
EDIT: I thought you meant robots. For Humans, you can't throw except for the last 30 seconds. Otherwise, discs must go through the feeder slots. And in the last 30 secs, only over the wall.
Unread 07-01-2013, 12:56
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Disc Throwing
Is there any rule about bringing something into the feeder station with you? Some shorter feeders might be able to take advantage of a box that they could stand on....
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 07-01-2013, 13:27
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Disc Throwing
In the past, that has been explicitly forbidden.
Former Mentor Team 1771
Former mentor Team 4509
Unread 07-01-2013, 13:31
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Disc Throwing
It is also difficult to throw a frisbee without good footing.
I think the question is during the last 30 seconds of play, do discs which human players throw over have to go directly over the feeding station?
A OI flick would go over the side netting curving back into the playing field. A OI back hand would go over the back driver station wall, and curve into the field.
Would throws like these be legal under the current rules?
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 07-01-2013, 14:37
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Disc Throwing
i saw nothing in the rules specifying how disks could be thrown.
Unread 07-01-2013, 14:59
AKA: Nathan Hui
Re: Disc Throwing
Actually, I believe the rules specify over the wall for throws, not around the side of the walls.
G35: DISCS may be fed onto the FIELD only under the following circumstances:
A. during TELEOP through the FEEDER SLOTS and
B. during the last thirty (30) seconds of TELEOP over the FEEDER STATIONS.
Violation: FOUL
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
