Go to Post We do have a good time. Mr. Bill - Bill Beatty [more]
Unread 18-01-2003, 18:17
Originally posted by rbayer
For something like this you could probably also use timing belts/pulley which would reduce weight as well.
GUI I believe this is one of the better ways to accomplish your task. A single timing belt running to both lead screws and the drive motor. More or less the belt would form a triangle with the lead screws at two corners and the motor at the third.
A second alternative, if space allows, is the drive motor with a sprocket, midway between the two screws, driving sprockets attached to the screws. (visualize three ring circus)
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
