Go to Post If all you've seen of an event is the three days of the competition, you've missed 99% of the work that made it happen. - Madison [more]
Unread 05-01-2013, 22:05
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Re: Building the Element
I have not built a pyramid yet but building the field elements the past many years leads me to one idea. Just for in school testing, not pre-contest event.
Making just one side not four.
Determine the width of the top (90 inch high) bar. Say it is 24 inches for example ( I have not done it yet). Make all 3 pipes, 30, 60 & 90 just the 24 inches wide. I would build it with 2 x 4s or 2 x 6s and the metal pipe. So the wood acts like stair stringers. Hole saw cuts a circle in the wood to slide the pipe through. Fastener to keep the pipe from spinning.
On a future game note, unless your robot can adjust left and right on the way up, you better start "perfectly" centered on the 30 inch tall pipe.
IF I CAD one up in SolidWorks I could share the drawings but it is not our top priority this week.
Good Luck!
Troy
St. Paul Minn. 2450
Unread 05-01-2013, 22:15
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Originally Posted by stinglikeabee View Post
How does it "feel"?
Our EMT based pyramid was unwieldy to build (we built for rung squares, and then added the legs, then the goal assembly. to add the goal we screwed it from below into the goal tray. When we used a clamp as a 'hook' to hold the goal down while screwing the structure flexed and pieces moved about 3" or more from their rest position. I wouldn't want to hang a robot (full weight) from the middle of a low rung and it will flex a lot, it not deform.
We used screws to attach the legs to the 2x4 wedge pieces -- we should have pre-drilled with a long bit because some of them started to split...
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 05-01-2013, 22:16
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
We (The RoboBees, FRC 836) plans on building the actual field pyramid. We may make modifications to the top scoring area (wood vs. polycarbonate), however.
If any teams are in the DC metro area do not have access to the field elements and would like to test on it or use it for practice, please get in contact with me via PM or send an email to Team836@RoboBees.org. We plan on having it complete this week thanks to help from 4514 Terminatrix.
Robobees!!!!
Who likes honey?
We do!!! Lol I don't know if you guys still remember us, but you bought honey for a member of our team last year (2537).
So if I understand what you're saying, it's that you guys are building THE ACTUAL pyramid that FRC detailed in "The Arena" section? Not the team section
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
Unread 05-01-2013, 22:25
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Originally Posted by gabrielau23 View Post
Robobees!!!!
Who likes honey?
LOL. I know all of the backstory with this one...
We plan to build a slightly modified version, but will have a gusseted and welded pyramid that should be very similar to the ACTUAL pyramid.
Unread 05-01-2013, 22:30
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Originally Posted by Davis Racing View Post
I plan to help build the pyramid so I did a little reading today. I noticed the team drawing design and the competition design have minor differences in specifications. The team drawing calls for 1 1/4" pipe (1.66 o.d.) with a 60 degree pyramid angle while the competition design calls for 1 1/2" tubing (1.5" o.d. plus powder coating) with a 68 degree pyramid angle. So, which design will we build!!!
Tentatively, I would say go for building with 1.5" 68 degree angle simply because that is what is defined in the game manual, which therefor means what would be on the field. If your robot isn't too dependent on the thickness of the piping, then you can go 1.25" tubing (I haven't done any research on this yet so I dunno if going smaller would cut costs or not.).
Academic Student (Forever)
Unread 06-01-2013, 00:06
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Don't be so sure about the one defined in the game manual. From the beginning of the Arena section:
Originally Posted by Arena Manual
Note: These illustrations are for a general visual understanding of the ULTIMATE ASCENTSM ARENA only. Please refer to the 2013 Official FIRST Field Drawings & Models for exact dimensions and construction details.
GE-13019 shows a 60 degree angle in the official drawings, which according to the manual have precedence. Hopefully we'll get something in the first update
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 06-01-2013, 00:12
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
I think I figured it out. If you look at page 56 of game specific drawings. There is a marking for 60 degrees. 60 is the angle between the 4 corner posts, and the horizontal plane.
68 is the angle between the horizontal members and the corner posts in the plane of the side.
The angle between the horizontal plane and the corner posts is different from the angle in the plane of one of the 4 triangular sides between the horizontal bars and the corner posts.
Visual aid two pencils in an L shape tilt the vertical pencil so it is 30 degrees off the table, its angle to the horizontal plane is 30, but the angle to the other pencil in the plane they share is still 90.
Additional hat tip to ZehP who did the math while I did my thought experiment:
Originally Posted by ZehP View Post
I did some math.
Let's start with the 4 corner poles each at a 60 degree angle.
If you measure the angle between the plane formed between two of these and the ground, you'll find that it's at about a 67.8 degree angle.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 07-01-2013, 10:04
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
I still don't see this fully....can someone post a drawn out visual of this?
Unread 07-01-2013, 10:32
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We built 2 here in Cincy, at least materials for 2. We built one for the Kickoff, which we left for Team 144 to use and have the materials for a 2nd at our shop. Once assembled it will stay up for the duration and be available for all area teams to use.
We also only built the feeder/Low goal combo and the High goal. Since the high goal and the middle goal overlap, we figure that if you can hit the high goal, you can hit the middle goal.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 07-01-2013, 12:54
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Team 2068 would like to thank our school's construction technology teacher for agreeing to build an "almost official" pyramid. It may not be done by this weekend but we can probably make it available for teams in Northern Virginia if you let us know you are coming. PM me for directions and such, I will post when its done as well.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 07-01-2013, 13:31
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
Like Caltran said, I suspect our team will use the CNC plasma cutter and cut out the plates. They will need some love to look good but should otherwise be very accurate. I imagine for material cost we might be able to make some more for local FRC teams.
-Mike
Unread 07-01-2013, 14:41
MrBydlon's Avatar
MrBydlon MrBydlon is offline
AKA: Jeremy Bydlon
FRC #3313 (Mechatronics)
MrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud of
FRC Team 3313 Mechatronics from Alexandria, MN has built an entire field wall out of plywood. Kinda crazy, we know. We are very fortunate to have the space to store them in our school's (former) automobile repair shop.
http://imgur.com/IDOSR
One of our sponsors is also building a pyramid out of steel using technical drawings for us.
Any teams in out state MN who would like to use them, please PM me, email me at 3313coach@gmail.com, or tweet at us @Team3313.
Unread 07-01-2013, 14:45
College Mentor
AKA: Trent Borman
Ill try to draw something up based on the PDF
Edit: Tried to show how the angles are measured (what planes they are measured in)
Unread 08-01-2013, 05:41
protoserge's Avatar
I made a thread to capture teams that are allowing others to use their field elements.
http://www.chiefdelphi.com/forums/sh...34#post1210534
Unread 08-01-2013, 08:50
My-smokepole My-smokepole is offline
FRC #0279
My-smokepole is an unknown quantity at this point
On the 104" pipe it calls for 7 holes drilled in each one I know what the
One is for but don't see what the other ones are being used for.
Or through hole for screw in 60dg block
David
My-smoke pole
David/toledo
Team 279
