Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 07-01-2013, 14:03
v2oxviesta's Avatar
v2oxviesta v2oxviesta is offline
Brendan
FRC #3926 (MPArors)
v2oxviesta is an unknown quantity at this point
2013 Field Pyramid Does not Match Manual Schematics
Hello!
I recently downloaded the Inventor CAD models for the 2013 season (Through the Autodesk website) and noticed that the models for the pyramid significantly differ from the way they are described in the game animation and manual.
Here is how it is shown on my computer:
And here is how the manual describes the pyramid:
Note: I am viewing these models in Inventor Fusion Mac
I will update this as soon as I can try viewing the models in Inventor Pro (Windows)
Unread 07-01-2013, 14:12
Nate Laverdure's Avatar
FRC #2363
Re: 2013 Field Pyramid Does not Match Manual Schematics
It looks like the gusset part wasn't loaded correctly... it was replaced by the weldment that supports the goal.
Unread 07-01-2013, 14:21
v2oxviesta's Avatar
Brendan
FRC #3926 (MPArors)
Also now that I look at it more closely, it appears that the legs are upside down. I have a hunch it might just be and inventor fusion problem
Unread 07-01-2013, 14:25
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Where did you download this? I am still only seeing 2012 stuff when following FIRST's link to Autodesk.
Unread 07-01-2013, 14:30
v2oxviesta's Avatar
Brendan
FRC #3926 (MPArors)
Today, even though it says '2012 Resources' there is a link to the 2013 KOP which is also accessible through their generic file management page. Here is a link (you need to login first):
http://students.autodesk.com/?nd=kitofparts_view&autodesk_submitted=Yes&period_ year=2013&sortby=&search_filter=&x=40&y=10
Unread 07-01-2013, 14:33
Domtech's Avatar
I Do Everything
AKA: Dominic
Thanks!! I actually have that page in my favorites, but I didn't think to look there directly.
Unread 07-01-2013, 14:35
KeeganP's Avatar
KeeganP KeeganP is offline
AKA: Keegan
FRC #2059 (The Hitchhikers)
KeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of light
I think it's just inventor fusion on your Mac... I downloaded it and it looks fine to me. The whole bottom half of the alliance stations was missing for me though, just goals floating in the air...
Here's what I get for the pyramid though:
The Hitchhikers Team2059.org
2011 NC Regional: Rookie All Star Highest Seeded Rookie, 3459
2012 SCRIW: Champions, 2059
2013 NC Regional: Finalists, 2059 (Thank you 1539 and 2655!)
2014 NC Regional: Industrial Design Award, 2059
2014 THOR: Finalist, 2059
2015 Palmetto Regional: Gracious Professionalism Award, Finalists (Thank you 1533 and 1261!), 2059
2015 NC Regional: Industrial Safety Award, Engineering Inspiration Award, Winner (Thank you 1225 and 900!), 2059
Unread 07-01-2013, 16:11
v2oxviesta's Avatar
Brendan
FRC #3926 (MPArors)
Okay, it is just an issue related to inventor fusion for mac. I opened the same files on my PC and got it working. Is there a place I should report a bug?
Unread 07-01-2013, 19:39
SpanishGal101's Avatar
SpanishGal101 SpanishGal101 is offline
AKA: Andrea
FRC #2826
SpanishGal101 is an unknown quantity at this point
Can you by chance give a different link to find the field CAD for inventer? I cannot find it using the link above
Unread 07-01-2013, 20:22
Ken Zaballos's Avatar
Ken Zaballos Ken Zaballos is offline
Ken Zaballos is on a distinguished road
A STEP version can be found here:
http://students.autodesk.com/?nd=kit...r=& x=30&y=17
You will have to use the pull down menu to select the right model. Select: "2013" AND "Competition Field STEP". The Pick "Go".
The model is not assembled correctly. It is a STEP file, so it comes in unconstrained. If you carefully re-constrain it, you can get a model that matches the Game manual.
Unread 08-01-2013, 13:01
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
All,
Some comments.
1. Yes, it looks like Fusion is not importing correctly. As shown in another screen capture the pyramid is OK when opened in Inventor.
2. I have updated some constraint values as per the original thread and will repost on the community. Downlaod if you need a more accurate model.
3. An updated STEP file is attached to this thread.
http://www.chiefdelphi.com/forums/sh...d.php?t=110680
4. If you are using STEP in a previous version of Inventor, select all the subassemblies in the browser. Right-click on the selection, and click Grounded.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
