Go to Post in other words, "always have something to do that will change up your life" - Nawaid Ladak [more]
Thread Tools Rating: Thread Rating: 8 votes, 4.63 average. Display Modes
  #46   Spotlight this post!
Unread 07-01-2013, 10:59
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Re: How to pick up a frisbee
In answer to the original question...
I'd be very tempted to steal an intake from VRC Gateway. Those had to pick up cylinders (though those cylinders were much taller) and the intake design that ultimately emerged was efficient and lightning-fast. Rollers are king.
  #47   Spotlight this post!
Unread 07-01-2013, 11:41
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by MrForbes View Post
Autonomous would not be the only advantage, but to me it appears to be the main advantage. Thinking of how many game pieces can be scored during a match, it's going to be a challenge for an alliance to use up all 45 in two minutes
I'd rather spend ten seconds picking up disks I and my partners just missed with and re-shoot them, than spend twenty seconds driving down to the feeder, getting fed, and coming back to score.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #48   Spotlight this post!
Unread 07-01-2013, 11:44
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you can figure out how to pick up 4 discs in ten seconds, then you definitely should be doing that.
  #49   Spotlight this post!
Unread 07-01-2013, 11:49
DonRotolo's Avatar
Back to humble
FRC #0832
Getting back to the thread title, how does one pick up a disk from the floor?
If we postulate a bot 24" wide, we can put rails near the floor (high enough to clear field imperfections) both fromt and back that funnel the disks to a given spot near robot center. Then, when a disk is detected in the right spot, rollers on both sides pop the disk up a bit. Something captures the disk and sends it off for further processing, maybe a pneumatic cylinder kicks it forward or something.
The rollers would be somewhat small diameter so they can catch the edge of the disk, maybe with little fingers of tubing instead of a solid foam/soft surface.
  #50   Spotlight this post!
Unread 07-01-2013, 12:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by Speeder View Post
I'm not sure that Autonomous would be the only advantage. Even if all the 'bots were able to score at an 80% average, that could leave ~25 game pieces on the floor if they stayed on the Field.
I suspect you will see much much higher accuracy in this game. The game pieces aren't highly variable, and from 15 feet away there is one magic rule for these frisbees: the faster you fire it and the harder you spin it, the more accurate it will be, and the less drop (or more rise) you'll get.
Go back and look at 2006, where you were shooting into a vertically oriented goal instead of trying to bank things in off the backboard. That should be a more accurate representation of accuracy, and top robots that year were absolutely deadly (85-90%).
Prototyping shooters is absolutely key (if you plan on being a shooting bot).
  #51   Spotlight this post!
Unread 07-01-2013, 12:11
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
How about if the rollers were inside out duct tape, like a lint roller? Just put on a new "belt" for each match, maybe?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #52   Spotlight this post!
Unread 07-01-2013, 12:16
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
Personally, I think that picking up frisbees will be a waste of time unless you can do it in under 15 seconds. Given that at the beginning of the match there are VERY few frisbees to be collected, the first minute or so should be a period when you aren't even using your collection mechanism. The last 50 or so seconds, the room starts to populate with frisbees. However, you still have the endgame to play. Plus since each alliance can use 17 frisbees, I doubt teams will be able to make 4 runs back and forth. @ 20 seconds a run, thats 80 seconds, or 1 min and 20 seconds elapsed in tele=op. you still have 40 seconds left. This isn't even taking into account problems like defense and unexpected stuff that just "happens". I think 20 seconds will be a very fast turnaround time near the beginning of the game. 30 seconds left people should definitely start going for the climb.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
  #53   Spotlight this post!
Unread 07-01-2013, 12:30
pfreivald's Avatar
Yup. The times I chose were somewhat arbitrary in illustrating my point:
To be a great robot you can't just do things well--you also have to do them fast.
Team 1551
I write books, too!
  #54   Spotlight this post!
Unread 07-01-2013, 12:36
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
There is a video this morning showing a shooter that seems to be able to make shots consistently from 50 feet.
So... one strategy might be to park at your feeder and just try to pump in shot after shot.
But.... if you miss, having a bot that could pick up from the floor and convert each miss to a score might be a big advantage.
And another strategy might be to shoot from the feeder into your end zone, have your teamates pick up and score. Lot quicker than driving around.
  #55   Spotlight this post!
Unread 07-01-2013, 12:43
AdamHeard's Avatar
Lead Mentor
I wasn't saying their shooter isn't precise, it could be for all I know. Just a word of caution to people trying to infer off the video. They only show a few shots, and with camera cuts. This could be a perfect shooter, it could be a mediocre one.
Teams really need to prototype and prove this for themselves to be truly confidant in their ability to perform.
Not only did they have higher accuracy in 06, but they were able to shoot MUCH faster than 2012 due to this.
  #56   Spotlight this post!
Unread 07-01-2013, 13:54
JohnFogarty's Avatar
AKA: @doctorfogarty
One of my co-workers sent me this. The end of the video is more pertinent than the beginning.
http://www.youtube.com/watch?v=mDlHG...ature=youtu.be
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #57   Spotlight this post!
Unread 07-01-2013, 14:11
DonRotolo's Avatar
Back to humble
FRC #0832
I think you may find the glue loses its effectiveness after a few pickups, but definitely TRY IT. Dont take MY word for it!
You mean, aside from the 10 or more already placed on the ground, and the autonomous shots that missed? I think you are wrong, but please dont take it personally.
Quoted for truth.
  #58   Spotlight this post!
Unread 07-01-2013, 14:17
DonRotolo's Avatar
Back to humble
FRC #0832
cool. I had seen that before, years ago, thanks for the reminder.
Just get something thin and flexible, like bumper cloth, hold it at the top and push out a thin sheet of something that rolls it out. Get under the disk, flip it up like a pancake, and repeat.
  #59   Spotlight this post!
Unread 07-01-2013, 14:30
nich nich is offline
FRC #3843
nich is an unknown quantity at this point
One of the ideas that our team has tossed around is using some kind of vacume device to create suction in order to pick up the frisbee. We found that it took very little suction to do so. If you are using suction you can pick up the frisbee no matter what side is up. But we havn't discussed how to get the frisbee right side up in order to throw it yet.
  #60   Spotlight this post!
Unread 07-01-2013, 14:57
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by donnie99 View Post
2. The rules state that you may block people at any point as long as they are not touching their pyramid, their safe zone next to the feeder station, and you do not pin them for more than 5 seconds. Although it would be against the spirit of FIRST and stopping the flow of the game, it is legal at this point in the season before any rule updates to block the feeder station. This is something that if seen at a competition, would most likely be changed for the rest of the season.
History would suggest the opposite. While FIRST has implemented many rules in order to encourage offense and protect offensive robots in the past few years, they haven't fully eliminated defense. Pushing and attempting to interfere with robot's transit across the field has been a long standing part of FRC games, and was a critical element in many games in which your alliance's human loaders are located on the far side of the field from where you score (2006 and 2011 being two recent examples).
