Go to Post "We'll fix that in programming" - EStokely [more]
Unread 07-01-2013, 15:36
nate825 nate825 is offline
AKA: Nathan Monforte
FRC #2191 (Flux Core)
Team Role: Student
nate825 is an unknown quantity at this point
Exclamation Climbing sequence (was: Please help)
With the pyramid, do you have to go level 1, 2, then 3 or can you go to level 2 right away. Thanks XD
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: Please help
Must climb in sequential order, 1,2,3
Unread 07-01-2013, 15:37
Jared Russell's Avatar
Taking a year (mostly) off
Re: Please help
This link. You need it.
Specifically look at Rule 3.1.5.2.
Unread 07-01-2013, 15:45
OzzyArmas OzzyArmas is offline
OzzyArmas has a spectacular aura aboutOzzyArmas has a spectacular aura aboutOzzyArmas has a spectacular aura about
Re: Please help
Does level 0 count as one of the two levels that you are allowed to touch simultaneously?
Unread 07-01-2013, 15:48
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Climbing sequence (was: Please help)
Yes, level zero does appear to be a part of the climb sequece we must follow (0 to 1, 1 to 2 ...). So if you are touching the floor, the only other place you may contact the pyramid is somewhere in level 1, untill your robot is off of the floor.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 07-01-2013, 16:03
Bob Steele's Avatar
AKA: Bob Steele
The way I see it:
Two concepts.... the ZONE which is used for scoring.
Whatever zone the lowest part of your robot ends up in determines your score.
Points are awarded for the highest Level achieved for every ALLIANCE ROBOT that CLIMBS its PYRAMID. The Level to which a ROBOT has CLIMBED is determined by the lowest point of the ROBOT (in relation to the FIELD). CLIMB point values and Levels are defined in Figure 3-4.
Climbing. This has to do with contact with the PYRAMID only...
In the glossary the pyramid is defined as
PYRAMID: the Red or Blue steel structure on which ROBOTS CLIMB for points.
By this definition the floor is not part of the PYRAMID
So the rule states:
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
sequential order (Level 0, 1, 2, 3) during ascent and
no more than two (2) Levels simultaneously.
This would mean that you have to touch the pyramid first in the lowest section and then you can reach up to level 2 (while sitting on the floor which is NOT part of the PYRAMID) and pull yourself up. (even if you contact the lower bar you are NOT contacting more than 2 levels (of the pyramid) at the same time
The trick is what do you do then? The final 10 points of the climb is quite difficult to accomplish... The first 20 points... not so much...
Good luck!!
Unread 07-01-2013, 16:07
Bob Steele's Avatar
AKA: Bob Steele
Please see my explanation above ... the floor is not part of the pyramid.
Please see the glossary for the definition of the pyramid.
Good luck!!
Unread 07-01-2013, 16:08
AKA: Jesse Gibson
Team Role: CAD
Originally Posted by Bob Steele View Post
The way I see it:
So the rule states:
Good luck!!
Interesting interpretation. If you are ont considering the floor a part of the pyramid then the climbing rule still states that you must contact somewhere in level 0 first right? (unless I'm misreading/interpreting). So would you then have to touch the base plate of the pyramid as level 0 first? In which case you still have to lift iff the ground before touching level 2. Hopefully this will be clarified in the team update comming soon since it has already caused so much confusion.
2011 - Logomotion
Unread 07-01-2013, 16:50
caltemus caltemus is offline
AKA: Charlie
FRC #0195 (CyberKnights)
caltemus is just really nicecaltemus is just really nicecaltemus is just really nicecaltemus is just really nicecaltemus is just really nice
I was under the impression that the steel plate supporting the pyramid was part of it. There was mention of the 1/4 inch lip around the pyramid. I see level 0 as being that plate.
195 alumni 2010-2012
Unread 07-01-2013, 17:27
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
There is already a thread dedicated to discussing the rules regarding climbing here.
These points have all been discussed in that thread already I believe.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 07-01-2013, 18:14
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Level 0 is the entire floor, not just the plate.
Unread 07-01-2013, 19:19
DMFrank's Avatar
DMFrank DMFrank is offline
FRC #1778 (Chill Out!)
Team Role: Tactician
DMFrank is an unknown quantity at this point
The way I see it:
So the rule states:
Good luck!!
Looking in the game manual at section 2.2.5, figures 2-7 and 2-8 and the description between them, its my understanding that the lip created by the floor protectors are what the GDC considers level 0.
