Go to Post It doesn't matter to me where a FIRST local event is held, I'll be there! - Barry Bonzack [more]
Unread 18-01-2003, 10:39
Brad Swindell Brad Swindell is offline
Brad Swindell is an unknown quantity at this point
The Ramp Mesh
How does the mesh go on the ramp, from bottom to top. on the attached pic, 1 or 2?
Unread 18-01-2003, 10:42
Jferrante Jferrante is offline
Jferrante is an unknown quantity at this point
Send a message via AIM to Jferrante Send a message via Yahoo to Jferrante
Unread 18-01-2003, 10:47
How do you mount it to the wood ramp?
Unread 18-01-2003, 11:07
I believe there using staples to do so, but i'm not positive.
Unread 18-01-2003, 11:08
Bob Merkel Bob Merkel is offline
Bob Merkel is an unknown quantity at this point
Send a message via AIM to Bob Merkel Send a message via Yahoo to Bob Merkel
nails
Our team had U-shaped nails. http://www.homedepot.com/cmc_upload/...7/A27257_2.JPG
They are grip-rite fasteners, Galvanized Staple. Commonly used to attach fences to wood posts.
Unread 18-01-2003, 18:42
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
We used a 1/16 inch think (i think) rectangle of aluminum with 2 holes in it. Then we used wood screws and screwed down the aluminum to our wood frame. Works great and it ends up being really flush with the top of the mesh.
Purdue Alumni
Cummins, Inc.
Unread 18-01-2003, 19:02
meaubry meaubry is online now
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
we stapled ours down
Unread 18-01-2003, 19:23
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
The very highest mesh needs to run Horizontal.
We used this extremely fun Air Powered stapler gun to hold ours down. Just be careful you don't staple into the floor.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 18-01-2003, 20:01
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
The actual field will have the mesh tack-welded to steel strips that run along the sections or the ramp.
wood planks under mesh:
Bolded = wood with strips.
Also the top's will have a steel strip welded on. The strips are then counter-sinked and screwed into place.
If you are building a practice field, staples should do the trick just fine.
Unread 18-01-2003, 21:19
I guess we need to know if you are using the metal or wood form of the ramp to know what to tell you would work. At least you now have an idea of how your team can do it.
Unread 21-01-2003, 17:00
Tempest's Avatar
Tempest Tempest is offline
#1155 (SciBorgs)
Tempest is an unknown quantity at this point
Send a message via AIM to Tempest
where did you get the top of the ramp ma terial from, and what is it??
is that a full sized ramp? because we are constructing a full sized ramp at our school.
Unread 21-01-2003, 17:07
Blacknight's Avatar
Blacknight Blacknight is offline
Duct Tape King
#0180 (S.P.A.M.)
Team Role: Driver
Blacknight will become famous soon enoughBlacknight will become famous soon enough
We just nailed ours down last night and it's definately 2 or else we're in trouble...
(\/)/\++ |)0\/\/|\|§
sn-TheGreatestKahn
Are there indelible lines that divide sanity from insanity, or do the overcross at the slightest change in the world...
Unread 21-01-2003, 17:31
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
We grinded down washers into rectanges that fit inbetween the wires on the mesh, then just screwed them down...holds quite nicely.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 21-01-2003, 18:02
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
The top surface of the ramp is white high density polyetheylene (HDPE). It can be purchased through most plastic suppliers and material suppliers. All the field details are on FIRST's website and in the rules.
Unread 24-01-2003, 15:51
Digo's Avatar
Digo Digo is offline
AKA: Rodrigo Ribeiro
#0383 (Brazilian Machine)
Digo is on a distinguished road
Send a message via MSN to Digo
How easy was it for you to find the wire mesh?
The most similar wire mesh we could find around here has the same space between the wires, but the wires are thiner and made of a weaker material. We will have to put something under it so the robot won't break it. That's bad to have a "similar' field.
Rodrigo Ribeiro
Team #383 - The Brazilian Machine
Mechanical Engineering student at UFRGS - Porto Alegre - RS - Brazil
Wire Mesh for Ramp MechaJagEric General Forum 2 27-01-2003 18:49
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Which wire mesh will be used? Jacqui Sutton Rules/Strategy 1 07-01-2003 00:51
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
