Go to Post Does FIRST know about some rare inverted mushroom that I do not? - sanddrag [more]
Unread 07-01-2013, 17:31
DStanizzi DStanizzi is offline
FRC #1073 (Force Team 1073)
Team Role: Scout
DStanizzi is an unknown quantity at this point
Re: Ultimate Ascent Disc Durability
Running the disc over upside down did not cause too much damage. The disc was warped slightly, and dented in some areas, but was easily pushed back to its original shape. After running the disc over multiple times with two cars, the disc was still intact and, amazingly, flew almost perfectly (the only problem was a slight wobble in the flight pattern). Eventually the discs would get damaged, but its not likely that they would get damaged to this point.
