#76
Re: Climbing Rules
#77
Re: Climbing Rules
I agree, and assume they'll clarify early on.
#78
Re: Climbing Rules
So I have a thought concerning the legality of grabbing the second bar while on the ground.
You'll note that the rules specify: Quote:
That may not be intent of the rules, but the wording is very strange. The pyramid is defined as just the steel structure, and doesn't mention including the carpet beneath. And given that Figure 3-4 seems to show Level 0 as being below the actual structure of the pyramid, is it even possible to contact the pyramid in Level 0? Perhaps a rewording of 3.1.5.2 is necessary? |
#79
Re: Climbing Rules
It's been noted. I'm sure it will be clarified quickly in the Q&A or team updates!
#80
Re: Climbing Rules
I am unable to find the blog post where Frank discusses it, but this sounds like "lawyering". The intent, I believe, is for the robot to be supported only by the individual level before moving on to the next level.
Of course, a Q&A submission and team updates will say for sure what the ruling on this is. |
#81
Re: Climbing Rules
Re: Climbing Rules
I think the manual makes it pretty clear that the floor is Level 0. Thus, you have to be completely supported by Bar 1 to touch Bar 2 and have it be part of a legal climb.
#83
Re: Climbing Rules
It would be great if the GDC puts out an update that includes diagrams of 'robots' climbing and showing legal and illegal climbing intermediate positions-- especially in relation to the floor and/or leg floor plates. Also examples that involve touching the legs of the pyramid. Sort of like they do for Ok/Not Ok bumper configurations.
#84
Re: Climbing Rules
The simple way is the best may be Pnaumatics
#85
Re: Climbing Rules
It isn't quite so clear about the floor being part of the pyramid, though. This is one spot where I expect an update to the rules.
#86
Re: Climbing Rules
Re: Climbing Rules
Re: Climbing Rules
:0) Before the update it was not clear that floor contact made any difference in climbing. |
#89
Re: Climbing Rules
Well, the rule change clarified whether you can touch the floor and bar 2 at the same time - Not!
Another scenario: The bar is at the top of a level. When you grab on the bar, part of your apparatus is above the bar, and in the higher level. Since it is not touching the pyramid above the bar, that is not a problem. Issue: What if you are grabbing at the corner? Or, if you want to grab the corner? Then, you will come into contact with a portion of the vertical pole that is above the horizontal bar. Question: Is there a portion of the vertical pole, immediately above the bar, that can considered part of the lower zone if another portion of the robot it touching the pyramid in the lower zone? If you are below the bar, then you want to be able to grab the corner and climb up, and incidentally be contacting the pyramid in the higher zone. Similarly, you could be a fraction of an inch above the lower bar, be contacting the vertical bar a fraction of an inch above the corner, grabbing onto the next higher bar, and should be considered as touching the higher zone (not touching any other part of the pyramid in the lower zone). It would be helpful to allow the 5 inches (or whatever nominal amount) of the vertical pole above a corner to be considered part of the lower zone if the robot is touching any other part of the pyramid in the lower zone. Or, for purposes of the 2 zone rule, the 5 inches of the vertical pole immediately above a corner is considered to be in whichever zone (actual zone, or immediately lower zone) that is most advantageous for the robot. Last edited by rich2202 : 09-01-2013 at 14:37. |
#90
Re: Climbing Rules
I'm not sure what you mean. The second bar is between Levels 2 and 3--certainly that's well out of the realm of "sequential" with zero regardless of what fraction of an inch they could ever allow in tolerance...
