Re: 2013 cRIO Imaging Tool too big for screen
That shouldn't happen unless you're using a very low resolution screen. If you're using a 13", 14", or 15" laptop then I would go into the display settings and make sure you're running native res. If you're using it on a netbook (like the classmate) you might either be out of luck. If you have a monitor handy, hook it into the classmate via VGA and use the extended desktop to give you the extra vertical space, otherwise just use a computer with a larger display.
If you are on the classmate we had the same problem.
Just auto hide the taskbar. Or if that does not work change the screen vertical. A bit bad but it gets the job done. |
A trick to move windows that are too big for your screen, if you can't use a bigger screen; press alt+space and then chose 'move' by clicking it, or pressing 'm' and then use the arrow keys to move the window around. I've used this a few times, and it seems to work for me. Let me know if you have problems or questions with it!
I entered a bug report here: http://firstforge.wpi.edu/sf/tracker..._bugs/artf1574
This is now on the 2013 Software issues list: http://wpilib.screenstepslive.com/s/...software-notes. They suggest using tabbing through the GUI elements to access the buttons.
