Go to Post Honesty and integrity should always be taken seriously. It's the lubrication that makes the world go round. - rsisk [more]
Unread 07-01-2013, 17:22
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
2013 cRIO Imaging Tool too big for screen
I was imaging our cRIO and when I brought up the tool it's too large for the computer screen. There's no way to resize the screen or move it so you can access everything in the window needed to image the cRIO.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 07-01-2013, 18:05
Re: 2013 cRIO Imaging Tool too big for screen
Can you adjust the computer screen to a higher resolution?
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
That shouldn't happen unless you're using a very low resolution screen. If you're using a 13", 14", or 15" laptop then I would go into the display settings and make sure you're running native res. If you're using it on a netbook (like the classmate) you might either be out of luck. If you have a monitor handy, hook it into the classmate via VGA and use the extended desktop to give you the extra vertical space, otherwise just use a computer with a larger display.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 07-01-2013, 18:24
ming08108 ming08108 is offline
FRC #4795
ming08108 is an unknown quantity at this point
If you are on the classmate we had the same problem.
Just auto hide the taskbar. Or if that does not work change the screen vertical. A bit bad but it gets the job done.
Unread 07-01-2013, 22:27
mocibot's Avatar
mocibot mocibot is offline
FRC #1829 (Carbonauts)
Team Role: Student
mocibot is just really nicemocibot is just really nicemocibot is just really nicemocibot is just really nice
A trick to move windows that are too big for your screen, if you can't use a bigger screen; press alt+space and then chose 'move' by clicking it, or pressing 'm' and then use the arrow keys to move the window around. I've used this a few times, and it seems to work for me. Let me know if you have problems or questions with it!
Good luck, stay safe, learn new things, and have fun!
I'm a student, because I don't fit in any one category.
Unread 07-01-2013, 22:43
I entered a bug report here: http://firstforge.wpi.edu/sf/tracker..._bugs/artf1574
Unread 08-01-2013, 17:06
This is now on the 2013 Software issues list: http://wpilib.screenstepslive.com/s/...software-notes. They suggest using tabbing through the GUI elements to access the buttons.
Unread 08-01-2013, 18:16
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
As stated before, if you go into the screen resolution options, you can set your screen to be a portrait landscape. It's a quick way to workaround the issue on the Classmate until it's resolved. Other, higher resolution computers don't have the problem, so you could consider installing the Imaging Tool on another computer.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
