Go to Post Read the manual. Know the manual. Love the manual. - Koko Ed [more]
Unread 07-01-2013, 18:10
SoulStealer16's Avatar
SoulStealer16 SoulStealer16 is offline
FRC #3654 (TechTigers)
SoulStealer16 is an unknown quantity at this point
Illegal Climb Method?
I was just wondering...
Does the entire robot have to be above the first horozontal on the tower before you can reach up and grab onto the second horozontal before you pull yourself (the robot) up?
Any help would be appreciated(:
Unread 07-01-2013, 18:16
V. Gray V. Gray is offline
Programmer/Team Captain
AKA: Ben
FRC #3881 (WHEA Robotics)
V. Gray is an unknown quantity at this point
Re: Illegal Climb Method?
From what I've read in the rules, there is no rule stating that the robot is required to be above the first horizontal to be allowed to hook onto the second horizontal. See 3.1.5.2 Climb Points for reference. Though, please feel free to correct me if I am wrong.
Unread 07-01-2013, 18:40
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I don't think so. As per 3.1.5.2 you cannot be in "contact" with more than 2 levels simultaneously. I don't know if being in the air of the scoring level is considered contacting it.
Unread 07-01-2013, 18:41
seabass94 seabass94 is offline
FRC #2874
seabass94 is an unknown quantity at this point
you're not allowed to be in contact with more than two levels at one time, the ground is level 0. Therefore your robot can't be touching the ground when it goes for level 2
Unread 07-01-2013, 18:49
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Right, my understanding of it is that the robot must be fully supported by level 1 before moving up to level 2, and then supported only by level 2 to move to level 3.
Unread 07-01-2013, 19:14
Okay, I understand what you all are saying, but now my question is, does the ground count as level 0?
Unread 07-01-2013, 19:24
Ayukura Ayukura is offline
FRC #1868
Ayukura is an unknown quantity at this point
If you look at this image (located in 3.1.5.2):
It clearly states Level 0 is the ground, although it is slightly elevated above the actual field.
Unread 07-01-2013, 19:31
DMFrank's Avatar
DMFrank DMFrank is offline
FRC #1778 (Chill Out!)
Team Role: Tactician
DMFrank is an unknown quantity at this point
Right. Look at figure 2-7 and 2-8. The PYRAMID is actually on a 1/4"-3/8" lip above the rest of the play field because of floor protectors they installed. This platform is level 0.
I wrote that quesiton wrong. What I mean was, If the ground level counts for level 0 that means we can't reach for level 1, be suspended between level 0 and level 1 and still reach up for level 2...correct?
Unread 07-01-2013, 19:35
tsullivan tsullivan is offline
Thomas Sullivan
FRC #2601 (Steel Hawks)
Team Role: Scout
tsullivan is an unknown quantity at this point
In the game manual, the ground level is defined as level 0.
Unread 07-01-2013, 19:36
FRC #1868
I apologize for having such a vague answer. DMFrank is most certainly correct; As I said Level 0 was slightly above the playing field. You can grab onto Level 1, but your robot must NOT be touching Level 0 before moving onto Level 2.
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
If your grabbing device goes over bar 1, and part of it is in level 2, and your wheels are on the floor, is your robot in 3 areas? I cannot find it anywhere in the rules, and the Q&A is not open. I also figured it was along the lines of this thread, so I figured I would ask here.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 07-01-2013, 20:05
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Check out this thread here.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 07-01-2013, 20:39
Chris is me's Avatar
AKA: Pinecone
You can be in three areas, you just can't touch things in more than two at a time, or out of order.
Unread 07-01-2013, 20:45
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
This is incorrect.
