Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 07-01-2013, 01:07
IBeMad IBeMad is offline
FRC #3968
IBeMad is an unknown quantity at this point
NetworkTable crash in unmodified SimpleRobot template
I'm getting a null pointer exeption in
NetworkTable::Initialize()
on the following line:
staticProvider = new NetworkTableProvider(*(mode->CreateNode(ipAddress.c_str(), port, threadManager)));
This crash occurs in unmodified SimpleRobotTemplate code. How does something like this even get through QA, or is there even any QA to begin with? Sure seems like there isn't any...
Earlier on in the call stack, the crash stems from
SimpleRobot::StartCompetition()
when it calls
LiveWindow *lw = LiveWindow::GetInstance();
which creates a new instance of LiveWindow since it's the first time GetInstance() is called, which results in it calling
NetworkTable::GetTable("LiveWindow")
When will this be fixed in WPILib, and how can I work around it in the meantime?
Unread 07-01-2013, 10:38
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
Re: NetworkTable crash in unmodified SimpleRobot template
Hi,
Are you sure that this is unmodified. We just ran the template project again and it worked fine. If you are still having issues would it be possible to do a little more debugging and figure out exactly what is null on that line.
--Mitchell
Unread 07-01-2013, 13:39
FRC #3968
Originally Posted by mitchellweb1 View Post
Hi,
--Mitchell
Yes, I'm sure that it's umodified. I guess I'll just have to fix the bug in WPILib myself and submit it.
Unread 07-01-2013, 15:58
I suggest that you reinstall the WindRiver update before blaming the library itself.
Unread 07-01-2013, 21:47
FRC #3968
No luck reinstalling everything, however it does work on other computers. Just not mine. Any other ideas?
Unread 07-01-2013, 22:32
AKA: Mitchell W
FRC #0190
If you could run the debugger and determine what value on that line is null then I may be able to try to help a little more.
Unread 08-01-2013, 01:48
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Fifthparallel is an unknown quantity at this point
Out of curiosity, why is there an asterisk in the argument for NetworkTableProvider? (I always get hazy around dereference operators)
Anyway, a null pointer exception would seem to indicate that something on that line is an uninitialized pointer. How/where did you declare staticProvider?
sudo chmod u+x helloworld.sh
gotta start somewhere.
Unread 08-01-2013, 09:30
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Originally Posted by Fifthparallel View Post
Well, not looking at the lib or anything, but it seems pretty clear that CreateNode returns a pointer, but the NetworkTableProvider constructor expects a value.
Proud alum of CORE 2062.
www.core2062.com
Unread 08-01-2013, 10:08
AKA: Sam Chen
FRC #1410
It looks like it expects an address to a node -- and if createNode returns a pointer, he has an asterisk in there that he doesn't need. I think that's the cause of his null pointer exception -- that asterisk creates an uninitialized pointer.
Unread 08-01-2013, 11:39
AKA: Mitchell W
FRC #0190
createNode will always return a non-null pointer. The NetworkTableProvider constructor takes a reference to the pointer type returned by createNode. This code has run fine on under linux and the crio so it is weird that it is failing here.
staticProvider is declared in NetworkTable.h
Unread 08-01-2013, 14:03
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
Could ipAddress contain the null string? If so, ipAddress.c_str() would return nullptr.
Unread 08-01-2013, 14:21
nightpool's Avatar
robotRectifier
AKA: Evan
This may be the issue. It probably stems from misconfiguration of the cRio or laptop. You should double check what team number you formatted it with.
www.core2062.com
Unread 08-01-2013, 23:59
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Exclamation Re: NetworkTable crash in unmodified SimpleRobot template
We were running into the same exact problem with our code but instead of WindRiver we were using makefiles similar to UCPP to compile our code (we don't have problems if we compile with WindRiver).
We tried setting the ipAddress variable to our robot's ip address manually, but that didn't fix the problem and since the its a server, the ipAdress seems meaningless.
We double-check the same thing too, but the error is still there. Did you have a particular configuration in mind?
When we were debugging the same issue, we found that both the mode and threadManager store non-null addresses. But whenever mode->CreateNode() was called, the null pointer error resurfaces. The variable mode is of type NetworkTableMode, so we replaced the code with
staticProvider = new NetworkTableProvider(NetworkServerMode::Server.CreateNode(ipAddress.c_str(), port, threadManager));
which still results in an error.
We are totally baffled; we just commented the livewindow stuff out as workaround but ultimately we need to figure out why this happens. Any additional suggestions? I remember there being a debugger that runs on the cRIO, but I'm not sure how that works.
Thanks!
-Masoug
JabbaScript
Unread 09-01-2013, 01:00
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Is there documentation that explains how the c++ networktable stuff works?
Unread 09-01-2013, 16:08
AKA: Mitchell W
FRC #0190
I have been unable to reproduce this problem. Try replacing ipAddress.c_str() with just "". It is actually ignored when in server mode (which it is always when running on the crio)
