Go to Post Practice bots are not regulated by FIRST. Your practice bot could have a flamethrower and a jamming device on it, and they wouldn't care in the slightest. You just can't compete at a competition with it. :) - AlecMataloni [more]
Unread 07-01-2013, 21:47
Acaellum's Avatar
Acaellum Acaellum is offline
4553 Programmer
FRC #4533 (Wando Advanced Roboics)
Acaellum is an unknown quantity at this point
Rule clarification (robot length)
It is about the robot's length horizontally.
If you are, say climbing the tower and are tilted up(example: http://i.imgur.com/lAv10.jpg) , you are still judged on you horizontal length, not you robot length. So you could have say, a claw that extends out, and increases the total length of the robot (diagonally) past 54 inches, but still remain under 54 inches measured horizontally, would you get penalized for having a robot longer than 54 inches.
I say no, you are within 54 inches horizontally, my teammates say yes, your length is over 54 inches, no matter the orientation of the robot. What says Delphi?
Unread 07-01-2013, 21:55
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Rule clarification (robot length)
What Delphi says doesn't matter. What the official Q&A says matters. Have your team utilize the official Q&A for clarification for official and specific rules questions such as this one.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 07-01-2013, 21:59
tanmaker
Posts: n/a
There would be no penalty.
"3.2.5.2 G23
A ROBOT’S horizontal dimensions may never exceed a 54 in. diameter vertical cylinder.
Violation: FOUL. If continuous or repeated violations, TECHNICAL FOUL.
In other words, a ROBOT must always fit inside a cylinder with a diameter of 54 in. This method for restricting ROBOT size requires extra diligence if a ROBOT’S geometric center shifts as various appendages are extended and retracted."
Unread 07-01-2013, 22:02
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
In the past with the same phrasing, the Q&A explained that these measurements were with respect to your robot rather than the field (ie if your robot was sitting flat, it would be within the cylinder). The GDC will need to issue a similar it contradictory ruling before this is known for 2013.
I was kind of hoping they'd address this upfront after last year's chaos.
Unread 07-01-2013, 22:58
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Also consider that if you increase the length of your robot by extending an appendage to 54", the width must be reduced to zero to allow it to fit within that cylinder to which the rule refers.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 07-01-2013, 22:59
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
You do realize we can't ask questions till Wednesday right?
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 07-01-2013, 23:46
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
I'd be pretty darn surprised if he didn't realize that. His statement still stands, though. Chief Delphi can speculate all they want, but ultimately what we think doesn't matter (in this kind of situation, at least) - it's the GDC that decides the game.
Not to say that we can't help answer some questions: if it's crystal clear in the rules (112" is 112" is 112" and that's the maximum frame perimeter), we can quote those all we want. If there's any ambiguity, we can speculate (though it is safer not to) but can't give a firm answer.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 08-01-2013, 11:31
$wimmer3138's Avatar
$wimmer3138 $wimmer3138 is offline
AKA: Andy Woodruff
$wimmer3138 is a jewel in the rough$wimmer3138 is a jewel in the rough$wimmer3138 is a jewel in the rough
Its a vertical cylinder meaning that he span 54 inches in 1 direction and span 54 inches in another direction as long as they still fit within the circle
FTC Innovators robotics(3311) '08-'09 World semi-finalists
FRC student (3138) '09-'12 - world semi-finalist and world quarter-finalist (#1 seed Newton '11)
Unread 08-01-2013, 12:13
Siri's Avatar
Dare greatly
I may be misunderstanding your statement, but you are treating the 54in as the diameter, not the radius, correct? (G23) If you extend a 54" appendage, as Bill correctly stated, your non-appendage width in that axis must be zero (which is impossible). You may extend a total of 54" in multiple directions, provided those directions are not anti-parallel from a single point. The former refers to an outside-frame-perimeter appendage, while the latter means total robot length.
Unread 08-01-2013, 12:27
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
The rule states playing configuration when giving dimensions. If you read the glossary for playing configuration, it states this is dynamic and can change through the match. My suggestion? Don't hang.cantilevered like in your picture, hang vertically and you can extended to 84"
Unread 08-01-2013, 12:37
AKA: Andy Woodruff
I read his comment as meaning it extended an appendage out to the 54 inch mark not a 54 inch appendage. Sorry for the misunderstanding.
Unread 08-01-2013, 12:52
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
G22 defines the robot height (60 or 84) in relation to the robot.
G23 defines the horizontal dimension of the robot. It does not specifically reference to the robot, but it could be taken as implied since G22 does.
It would seem that when climbing, the 54" cylinder & 84" height would be referenced to the robot. But as others have said, my opinion is not the one that matters.
Unread 10-01-2013, 13:50
Acaellum's Avatar
4553 Programmer
https://frc-qa.usfirst.org/Question/15/questionlink
