Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
Unread 07-01-2013, 19:45
NinjahLover NinjahLover is offline
FRC #4081
NinjahLover is an unknown quantity at this point
Post Robots Hanging on Each Other
Is there any way we'd be allowed to have another robot hang off of ours while we're at the 90" tier?
Unread 07-01-2013, 19:50
Suitster's Avatar
Suitster Suitster is offline
AKA: Ethan Pellittiere
FRC #3951 (SUITS)
Suitster is on a distinguished road
Re: Robots Hanging on Each Other
Rule G33: A ROBOT may only be supported (fully or partially) by another ROBOT if one of the ROBOTS is in contact with a PYRAMID.
So yes, it is allowed in the rules.
2012 FLR Regional Champs, with 1507 and 191
Unread 07-01-2013, 19:54
kelseysea
Posts: n/a
G33 "Violation: If extended, strategic, or repeated, TECHNICAL FOUL."
Having another robot hang off of yours for points could be considered strategic, correct?
Unread 07-01-2013, 19:58
Suitster's Avatar
FRC #3951 (SUITS)
It only applies when the rule is being violated
Unread 07-01-2013, 19:59
kelseysea
Posts: n/a
Ah, okay. Thank you.
Then you could have another robot hang off of yours on the pyramid.
Unread 07-01-2013, 21:11
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
While it is certainly allowed for one robot to support another, you will have to be careful if you are trying to get points. Specifically refer to section 3.1.5.2
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
-sequential order (Level 0, 1, 2, 3) during ascent and
-no more than two (2) Levels simultaneously.
So if the robot you assist has not contacted the pyramid correctly, it may not count as a valid climb (and thus provide points).
Unread 07-01-2013, 23:24
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Is the ideal robot for this going to be a 2337 Breakaway type or a robot that hangs itself and drops a winch for others?
Academic Student (Forever)
Unread 07-01-2013, 23:55
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
The ruling states that a robot must contact the pyramid in ascending levels. If you picked them up, they will have properly satisfied this constraint in my understanding of the rules.
They will have only contacted level 0. You can't fail at touching in succession if you only ever touch one zone. It works as long as the robot being lifted doesn't touch the pyramid during the lift, by my interpretation.
Another issue to consider is to make sure you stay under 84" tall during the lift.
Unread 08-01-2013, 00:07
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Due to the top of the inside of the pyramid being 24" x 24" I don't think it's very possible to get 2 robots in the 30 point level on the inside unless they are extremely small.
It is completely feasible to drop a line to have them come up the inside to the second scoring level, using a piece of lexan sticking out to hit each bar as the ascended.
As for the 84" rule, you would take the maximum required to get them to level 3; 90" and subtract their robot height from it. As long as they are 7+" tall you wouldn't break any rules.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 08-01-2013, 00:12
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
You are correct that they will have only contacted level zero, and aren't in violation of any rules. However, points are only awarded for CLIMBS, and CLIMBS require sequential contact. Therefore, they would get no points, even if they are above 60".
At least this is my interpretation, since the definition of CLIMB specifically says "contact". A Q&A would clarify.
