Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
  #136   Spotlight this post!
Unread 07-01-2013, 23:03
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Climbing Mechanism Ideas
Originally Posted by frank.pendzich View Post
...I believe this contest is really a test of team’s abilities to work together to scale that structure. That may be the reason why an individual robot can’t make contact with more than two rungs at a time and can only skip the first rung. It seems that we’re being setup to work together and it’s that feature that may in fact be designed into the game as the desired outcome by the game’s designers.
Under what circumstances can a robot skip the first rung? I read the game manual 3.1.5.2 as requiring contact with the pyramid in each zone (to get the points of the higher zones). Maybe you meant a robot climbing up the corner, so it contacts the pyramid on the corner piece in zone 1?
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #137   Spotlight this post!
Unread 07-01-2013, 23:04
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Here is a way two robots working together could score 40 points legally, relatively easily.
Robot A: Flat top 8" off the ground with a ramp.
Robot B: Vertical arm with hook on top, extendible to 83 inches (max height is 84 inches)
1) Both robots drive into pyramid.
2) Robot B drives on top of robot A.
3) Robot A drives to center of pyramid.
4) Robot B extends arm 25 inches (25+8=33)
5) Robot A drives so robot B's arm taps zone 1 bar.
6) Robot A drives to center of pyramid.
7) Robot B extends arm 55 inches (55+8=63)
8) Robot A drives so robot B's arm taps zone 2 bar.
9) Robot A drives to center of pyramid.
10) Robot B extends arm 83 inches (83+8=91)
11) Robot A drives so robot A's arm hooks onto zone 3 bar.
12) Robot B retracts arm (or activates winch) and raises itself straight up into zone 3 for 30 points.
This sequence follows the rules for climbing the pyramid precisely, robot B contacting each level sequentially and never contacting more than two levels at once.
For even more scoring goodness, robot A then raises an arm, hooks the zone 1 bar and lifts off the floor for another 10 points.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #138   Spotlight this post!
Unread 07-01-2013, 23:05
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by Randomness View Post
It also depends on how you interpret the climbing rules... but it is my belief that robots have successfully climbed if they get to level 3 height without touching any parts of the pyramid.
That seems to be in direct conflict with the rules.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #139   Spotlight this post!
Unread 07-01-2013, 23:08
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Originally Posted by ToddF View Post
Here is a way two robots working together could score 30 points legally, relatively easily.
Teams had a hard time feeding balls to great shooters last year so I feel safe in saying this is not going to happen.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
  #140   Spotlight this post!
Unread 07-01-2013, 23:26
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I'm not committed yet to the idea that scoring and climbing are entirely separate in terms of legality. I think there is some ambiguity that will need to be clarified on Wednesday. One reason is the weirdness of the idea that you must touch the footing (level 0) of the pyramid before progressing to the first rung. 3.1.5.2 could be interpreted as equating the "pyramid" not with the metal bars but with the zones controlled by the bars.
The implications of zones rather than bars are:
1) it will be a lot more difficult to grab the bars if level 1 ends at the plane tangent to the top of bar 1; climbing the corners may be the only feasible method.
2) If a robot is fortunate enough to have reached level 2, it could drop a line to a waiting alliance member below, and carry that robot up enough to no longer be in level 0.
If bars rather than zones,
1) climbing the rungs becomes more feasible (though still difficult).
2) a robot at level 3 could lower a cable to a robot partner on the ground, and lift it up, so long as the lower robot reaches out and touches the pyramid at specific points.
  #141   Spotlight this post!
Unread 07-01-2013, 23:30
TRIron95 TRIron95 is offline
FRC #4206
TRIron95 is an unknown quantity at this point
Extending the arm over 54" seems to be in violation with the rule that says your robot must never extend outside a 54" diameter cylinder.
  #142   Spotlight this post!
Unread 07-01-2013, 23:36
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
I believe he means to extend the arm 54" vertically, rather than horizontally.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
  #143   Spotlight this post!
Unread 07-01-2013, 23:37
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
The max envelope is a cylinder 54" in diameter, 84 inches tall.
Todd F.
Photo gallery
video channel
Triple Helix mobile
  #144   Spotlight this post!
Unread 07-01-2013, 23:39
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
For any teams that have a 3D printer, I just published a design that might help you think about climbing. I made the model for my desk at home so I can stare at it and imagine all the robots climbing up.
http://www.thingiverse.com/thing:40727
  #145   Spotlight this post!
Unread 07-01-2013, 23:43
mrnoble's Avatar
teacher/coach
That is super cool.
  #146   Spotlight this post!
Unread 07-01-2013, 23:44
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
I believe this is the interpretation that was intended. They would not have made the pyramid as it is without intending teams to climb the outer or inner 'faces' of the pyramid.
your second point about lifting a robot that touches each section in sequence (probably by being bounced off the horizontal bars along the way) seems like a legal corner case to me.
  #147   Spotlight this post!
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Here's another cooperation idea.
The trickiest part of the climb is leaving zone 0 before touching the zone 2 bar. If you could sit on the floor and reach up to the zone 2 bar (touching zone 1 bar first, of course), inch worming up to the top isn't too hard.
So, robot A deploys a tarp from a roll and tows the tarp under the lowest bar, spreading it out to cover the ground. The tarp could be pretty big and not violate the 54" diameter rule. Robot B drives onto the tarp, thus leaving contact with zone 0, and inchworms up the pyramid, from bar to bar.
Robot A then reels in the tarp and hangs for ten points. Much less coordination between the two robots.
Todd F.
Photo gallery
video channel
Triple Helix mobile
  #148   Spotlight this post!
Unread 08-01-2013, 00:35
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
On the subject of coopertition...
A few kids on my team had the idea of a skyhook that would reach down and grab a friendly robot by attaching to the eyelets/connecting points that are meant for the belay system. Making a skyhook, though, will be tough.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #149   Spotlight this post!
Unread 08-01-2013, 00:54
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
I thought skyhooks were in the same genre as snipe hunts. Odd that they would be useful for design ideas...
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
  #150   Spotlight this post!
Unread 08-01-2013, 01:11
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
Just prop yourself up on an air cylinder "foot" on top of a frisbee, throw a batman hook to rung 2 (making sure to somehow touch rung 1 in the process) and hang for a quick 20, or climb for a slower 30.
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
