Go to Post Saying that something cannot be done, is always good inspiration for someone to find a way to do it. - Josh Hambright [more]
Unread 07-01-2013, 17:12
skottmorris's Avatar
skottmorris skottmorris is offline
FRC #4909 (Bionics)
skottmorris is a jewel in the roughskottmorris is a jewel in the roughskottmorris is a jewel in the roughskottmorris is a jewel in the rough
Linear Path Shooter vs. Circular Path Shooter?
Has anyone considered a linear path shooter for their design?
Everything I've seen on YouTube is built with a circular path. I'm curious if this was for design convenience or there is some magic to the disc following a circular path. My team has proposed creating a linear path shooter with two parallel motors to "spin" the disc down the launch path. Has anyone tried this? If it works, it would make a nice compact shooter.
Unread 07-01-2013, 17:19
Re: Linear Path Shooter vs. Circular Path Shooter?
http://www.youtube.com/watch?v=GT88vWTYgj0
http://www.youtube.com/watch?v=iyE4Ir6dkY8
Unread 07-01-2013, 17:22
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Beaten to the punch, but:
http://www.youtube.com/user/robotin3days
in particular
http://www.youtube.com/watch?v=iyE4I...SDSA& index=2
Unread 07-01-2013, 21:37
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A circular path shooter allows more distance while the disc is in contact with your shooter wheel. This will allow the disc to speed up to more closely match your shooter wheel speed. That isn't necessarily good or bad. Last year it was important because you needed very consistent speed and spin.
This year, I'm guessing not so much.
Unread 08-01-2013, 00:11
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
A linear shooter seems, from all that I've seen, much easier to deal with. Easier to load, easier to fit, and potentially easier to manufacture (you've got to get that curve just right, and keep it that way).
This comes at the expense of being slightly less accurate and slightly less powerful. Our team hasn't made it that far into the prototyping stage yet, so I can only speak from what I've seen others do.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 08-01-2013, 02:50
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
As has been said, its a matter of contact speed.
The circular pathway allows more contact time between your spinning wheel and the frisbee. This gives the wheel more time to accelerate the frisbee to more closely match its own tangential velocity.
In a linear pathway, the wheel touches the frisbee for a fraction of a second; thus, a fraction of the speed of the wheel is delivered to the frisbee.
Of course, there's dark magic with various other variables such as the compression of the frisbee, space between wheel and a guide rail, type of wheel, surface area of wheel, as well as the torque and speed of the accompanying motor.
It's a matter of testing
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 08-01-2013, 02:53
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
What says the linear shooter only touches the frisbee at the tangential point of the wheel? I can think of a way to have the frisbee in contact with the mechanism for a longer period of time.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 08-01-2013, 04:37
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
Please elaborate?
Unread 08-01-2013, 06:03
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Originally Posted by ohrly? View Post
Please elaborate?
A linear pathway with a belt along the length to give the spin and forward speed might just do it.
Unread 08-01-2013, 07:51
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
So you're going to run a linear belt, essentially a conveyor on it's side, at thousands of rpm and expect that to work the same as a wheel going thousands of rpm?
Academic Student (Forever)
Unread 08-01-2013, 07:59
Robogineer1649's Avatar
Robogineer1649 Robogineer1649 is offline
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Robogineer1649 will become famous soon enough
We built a prototype and it had two parallel wheels as you were saying you might try. I must add that it was in a linear fashion. But what i really want to tell you is that the frisbees go much further if one side is stationary compared to both sides spinning. Additionally our team has not tried to make a half circle shooter design only a linear so i can not take about that aspect of your question. What i can ask you is why would you use a half circle shooter that takes up much more space especially this year with smaller robots rather then building a linear shooter that works just as well?
Unread 08-01-2013, 08:20
knuckleduster knuckleduster is offline
AKA: Jack Manning
FRC #0058 (The Riot Crew)
knuckleduster is an unknown quantity at this point
In our tests in the shop we have found that linear shooters are not as accurate as circular shooters and don't shoot as far. I hypothesise that it is because the wheel doesn't get to work on the disk as much (W=FxD) and will therefore put less energy into the disk before it is released.
Here are videos of our attempts:
http://telly.com/01F3LB
they should all be on there.
Unread 08-01-2013, 08:21
Jared Russell's Avatar
Taking a year (mostly) off
Theoretically there is no difference. For a given contact length, CoF, compression, and surface speed, and a given energy supply (including any storage of rotational energy via flywheel effect) the shape of the pathway is irrelevant.
Theoretically.
Unread 08-01-2013, 08:56
You are not limited to one wheel with a linear shooter design. Watch the videos posted here.
Unread 08-01-2013, 09:48
FRC #1514
I am not saying that a belt is the best way, rather just pointing out that it is a method that would work or maybe I should say, should work.
A multi ribbed flat belt will run at 3600 rpm with no problem at all on a 4 inch diameter wheel which translate to a very fast linear speed.
