Go to Post Hold on to your shirts kids, here comes some physics... - JesseK [more]
  #31   Spotlight this post!
Unread 08-01-2013, 09:13
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Re: Building the Element
Originally Posted by Davis Racing View Post
I plan to help build the pyramid so I did a little reading today. I noticed the team drawing design and the competition design have minor differences in specifications. The team drawing calls for 1 1/4" pipe (1.66 o.d.) with a 60 degree pyramid angle while the competition design calls for 1 1/2" tubing (1.5" o.d. plus powder coating) with a 68 degree pyramid angle. So, which design will we build!!!
See
http://www.chiefdelphi.com/forums/sh...d.php?t=110678
  #32   Spotlight this post!
Unread 08-01-2013, 09:27
MentorPrice's Avatar
MentorPrice MentorPrice is offline
Mentor/FIRST Alumni/Engineer
AKA: Kevin Price
FRC #1708 (Amp'D Robotics)
MentorPrice is an unknown quantity at this point
I would just also throw a word of caution to any team trying to build the pyramid because of safety hazards and structural integrety. I would personally build the scoring goals instead.
But dont let me dampen your experience, if you want to build a pyramid, test it and make sure that it is secure and strong enough before attempting any practice let alone horseplay near or on the apparatus.
Team #1708 Drive Team & Member (2006-2008)
Team #4547 Westmont Hilltoppers Mentor (2013-2014)
Team #1708 McKeesport Amp'D Robotics Mentor (2009-2012, Current)
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.”
Nikola Tesla
“A Machine to End War” (Liberty, February, 1935)
  #33   Spotlight this post!
Unread 08-01-2013, 09:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
G02
Teams may not climb on the PYRAMID.
Violation: YELLOW CARD
I was thinking we might want to implement this rule during build season....
We are planning on building enough of a pyramid to test our robot's ability to climb it. So far, it looks like we'll need one horizontal bar, 30" off the floor. We haven't figured out a way to climb any higher than that.
I priced .095" wall 1.50" structural steel tube at the local welding/steel supplier, it goes for $2.00/ft in full lengths (20 ft), and $2.50/ft if cut to a specific length. How much do we need?
  #34   Spotlight this post!
Unread 08-01-2013, 09:54
ezygmont708's Avatar
ezygmont708 ezygmont708 is offline
FAIL = First Attempt In Learning
AKA: Zygmont
FRC #0708 (Hatters Robotics)
ezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant future
Team 708 built the pyramid on Sunday. We noticed a few things of extreme importance. First was that the hole in the wooden corner brackets when drilled to spec was too large. We drilled a 2 1/4 inch hole instead, then sanded down the points of contact (allowing the pole to take the angle of the support 2x4). It is very important to ensure that the holes for the u brackets are correct. We also noticed that the u-bolts (purchased at Lowes) were not made to a tight tolerance. The fabrication of the necessary pieces took about 6 hours, and construction took about 2 hours. If you plan on constructing I would suggest acquiring a 4 inch deep socket the size of the nut for the u bolt. This will save you a lot of aggravation. When assembled the pyramid seemed very sturdy, enough that one of our mentors (200 + lbs) felt comfortable enough to do a few pull ups on the third rung. Our team has also instituted a no climbing rule!!!
If there are any teams in the philly area that don't have the time, space, or means to build the pyramid send me an email (ezygmont@team708.org) and we'd be happy to have you over.
E. Zygmont
Team Lead - Team 708 Hatters Robotics
Hatboro- Horsham Senior High School - Horsham, PA
  #35   Spotlight this post!
Unread 08-01-2013, 10:16
ronmarkum ronmarkum is offline
FRC #1750
ronmarkum is an unknown quantity at this point
We used 1-1/4 EMT. Its about 1/3 the cost of black pipe, a lot easier to cut, and measures 1.51 OD. It is plenty strong. We will be welding ours in the near future. I don't think the u-bolts and plywood will withstand many climbs.
  #36   Spotlight this post!
Unread 08-01-2013, 11:44
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Originally Posted by ttldomination View Post
I feel like the goals can be fairly easily simulated by some cardboard boxes placed at different heights. You could tape up the boxes wherever you practice?
- Sunny G.
Have you considered a polytarp with appropriate holes cut and taped. It could then be fastened to a piece of EMT and slung from roof trusses. No chains behind the holes but it's cheap, easy to make and easy to store.
  #37   Spotlight this post!
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
EMT is usually galvanized. Should only be welded with proper precautions. (Google "Metal Fume Fever" for details.)
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
  #38   Spotlight this post!
Unread 08-01-2013, 22:09
My-smokepole My-smokepole is offline
FRC #0279
My-smokepole is an unknown quantity at this point
I got Schedule 10 black pipe sprinkler line @ $1.00 a ft. Came out of a plumbing supply house.
David
My-smoke pole
David/toledo
Team 279
  #39   Spotlight this post!
Unread 08-01-2013, 22:21
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We are building a scaled version of the pyramid to test out some scaled mechanisms on the pyramid, and so we can get a feel for how climbing can be done.
This is partially because if we did build an actual pyramid, it would be too tall and take up about 60% of our workspace.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
