Go to Post Health. Family. School. FIRST. Any other order is a mistake. - pfreivald [more]
Unread 07-01-2013, 16:07
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Exclamation Discrepancy in dimensions for steel tubes for pyramid
pg 19 paragraph 1 of the game manual:
The PYRAMID is made out of 1 1/2 in. diameter
steel tubing and powder coated Red or Blue.
Yet the Team drawings for the field say they are 1 1/4 in. diameter steel tubes. We need a clarification on this, please.
Unread 07-01-2013, 16:31
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Re: Discrepancy in dimensions for steel tubes for pyramid
The actual field parts are dia 1.5 steel tube. The team drawings call for 1.25 pipe. Steel tube is measured by outside diameter. Pipe is measured by outside diameter and wall thickness - called Schedule. 1.25 pipe has on OD of 1.66 - 0.160 over 1.50 so it isn't a match. Schedule 40 (the most common) has a wall thickness of 0.140 for an inside diameter of 1.38 Pipe is cheaper and more readily available (Home Despot) than steel tube. It can also be threaded and fittings are readily available for it.
Unread 08-01-2013, 11:39
TechDesigner TechDesigner is offline
FRC #3350
TechDesigner is an unknown quantity at this point
I wish the tech specs for the pyramid had clearly specified what schedule to use. I have spent some time on the phone this morning with my local steel supplier. He says just go with schedule 40. The outer diameter is 1.66" as specified in the cad drawing, and he says that a 8' length of it would easily support a 150lb. robot. PLUS - It's much cheaper! Yea! Best of luck to you!
Unread 08-01-2013, 11:54
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
And Powder Coat usually adds real thickness, reducing the difference between the two.
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
