Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 08-01-2013, 12:05
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Re: How to connect to the cRIO
Originally Posted by DjScribbles View Post
For a point of clarification, reimaging the crio is essentially wiping the flash storage completely, and reinstalling the OS. When you are programming, you copy your program onto the crio and it gets executed by the OS from the image you put on, you can replace your program all season without reimaging; the only reason to reimage is if you suspect corruption, or an updated image is released.
Did not know this! That's much better actually So then I just need to reimage it this one time and I should be fine
Now to look up how to change the code without reimaging the cRIO
Team 3753 BulahBots
