Go to Post I live for the offseason...that is, when i'm not living for the actual season. - Libby K [more]
Unread 07-01-2013, 22:05
Robobuff1.0's Avatar
Robobuff1.0 Robobuff1.0 is offline
FRC #1633
Robobuff1.0 is an unknown quantity at this point
[FTC]: Encoder programming in labview for teleop
Hi so my team is using encoders this year and I'm not familiar in programming them. Our plan was to incorporate encoders in our teleop code. Like for example when I press button 1 I want the arm to go to a specific position using the encoder. I've been researching and doing trial and error for about a month now and can't quite get it any help will be much appreciated Thank you in advance.
FRC: 1633
FTC: 2873
Unread 08-01-2013, 00:59
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: [FTC]: Encoder programming in labview for teleop
So an encoder is simply a sensor that tells you how much the encoder has rotated. For moving an arm to a specific position, you need to use a control algorithm such as PID. PID works by calculating a power setting for the motor based on the arm's current position (taken from the encoder) relative to the position you want the arm at. If you're in FTC, I believe you'll be using either NXT-G or RobotC (are there others?), however, I'm only familiar with RobotC.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 08-01-2013, 08:36
FRC #1633
We are using lab view and I'm familiar with what an encoder is but what's confusing me is how to set up the PID structure
FRC: 1633
FTC: 2873
Unread 08-01-2013, 09:06
Could you be a bit more specific? It's not clear what you mean by "set up the PID structure".
For example, here's a link to the LabVIEW help section for PID. If you could identify what part of it is confusing, it would help get you targeted answers.
Unread 08-01-2013, 12:15
FRC #1633
I would like to execute a code once when I click a button on the controller. Like when I click button 1 on the controller I want the arm to move to the specified enconder position and stay there until I press another button to retract it. I just need an example to work with.
FRC: 1633
FTC: 2873
Unread 08-01-2013, 12:37
When you press the first button, your code should set the PID setpoint to whatever position you want the arm to go to.
When you press the other button, your code should set the setpoint to whatever position corresponds to "retract".
Does your version of LabVIEW have examples? That would be a great place to look.
Here's another good resource:
http://team358.org/files/programming...2009-/LabVIEW/
Unread 08-01-2013, 12:54
FRC #1633
The link you gave me is labview for FRC, is it similar to labview ftc
FRC: 1633
FTC: 2873
Unread 08-01-2013, 12:58
Check to see if your LabVIEW installation has built-in examples how to use PID. If it does, that's usually a very good place to look for help.
