Go to Post Woah, boulders fired. - FrisbeeFunTime [more]
Unread 08-01-2013, 13:27
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: 2583's prototype shooter
What was the RPM of the CIM? Was there any reduction off the CIM, or was it straight direct dirven off of it? For this prototype, was it just battery->cim->wheel->frisbee?
Academic Student (Forever)
Unread 09-01-2013, 00:53
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
To answer a few questions
The shooter was about waist high, so 3 or 4 ish feet off the ground and it was angled up with just a 2x4 under the front
The wheel is direct driven by the CIM and just directly hooked to a battery. I believe this leads to around 4000 RPM
At first we cut the wood circle and placed it exactly 11 inches away from the wheel
Then we added two polycarbonate sheets, each 1/8 in thick to the inside of the curve. So we ended up with only about 1/4 in of compression
We were wondering how changes in RPM vs compression would change the trajectory and we found that using a half dead battery, so a lower RPM, the frisbee only flew marginally less distance and was stills table. However, removing just one 1/8 in sheet of polycarbonate caused the frisbee's range to drop from 50 to about 10 feet.
We will be trying a higher angle soon, however based on other videos, including the Robot in 3 Days robot, shooting at a higher angle will still work
Unread 09-01-2013, 02:27
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
What wheel did you guys use? It looks like a lunacy wheel.
EDIT: I read the other posts more carefully, it's a 6" KOP wheel from this year. Sorry for not reading.
https://kusha.me
Unread 09-01-2013, 11:06
Once up to speed, the only external load on the CIM is windage and vibration due to unbalanced wheel. At 12 volts and 4000 rpm, the CIM would be drawing 34 amps and generating 250 watts of output power at the shaft. If you guys have a clamp-on ammeter, it would be most interesting to see what the current draw actually is.
We were wondering how changes in RPM ... would change the trajectory and we found that using a half dead battery, so a lower RPM, the frisbee only flew marginally less distance and was stills table.
Not sure what you mean by a "half dead" battery.
Do you plan to do closed-loop control of wheel speed? If so, when you get the speed sensor mounted you could provide some useful data to the CD community showing how rpm affects the frisbee flight path.
Unread 09-01-2013, 19:14
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
I'd love to see some useful data too!
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 14-01-2013, 00:05
FRC #2583
here is the second version of our frisbee shooter
We have our CIM directly mounted to a 6 inch White KOP wheel from 2013
The wall is two pieces of 1/16 in sheet metal mounted at two points causing compression of about 1/4 in
We are shooting at a 30 degree angle, and the axle of the wheel is 120 inches from the Alliance Wall
This is around where the base of the pyramid is because our plan is to back up into the pyramid so that we always have the same position, similar to how teams used the fender last year
http://www.youtube.com/watch?v=EjK6m...ature=youtu.be
Unread 14-01-2013, 09:45
ttldomination's Avatar
Sunny
Is it just me or does it sound like your wheel is experiencing some fairly drastic slow down?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 14-01-2013, 10:43
Originally Posted by ttldomination View Post
Is it just me or does it sound like your wheel is experiencing some fairly drastic slow down? .
This could be the reason, no speed control:
The CIM [is] just directly hooked to a battery.
...and no headroom for speed control unless the shooter is reconfigured so that the CIM needs less than 12 volts to maintain the desired operating wheel speed.
The flexible curved guiderail is an interesting concept; first video I've seen of such.
Unread 14-01-2013, 11:19
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We use a curved guiderail, we found that it icreases our accuracy significantly. I plan on releasing a video later today along with some test results. For now you can see some slow motion shots we took last night at the very end of this video. It also shows three shots and where they landed about 25' away.
https://www.youtube.com/watch?v=Orsk...e_gdata_player
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 14-01-2013, 11:27
Many teams have prototyped, and have posted videos of, shooters with curved guiderails.
My post was referring to a flexible curved guiderail. Watch Team 2583's video again, and pay close attention to the guiderail.
Unread 14-01-2013, 12:38
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Sick, Lets see the hopper/feeder system now
edit: Do you have any sort of guide system on the shooter? Ie. Something to restrict the movement of the Frisbee to one path each time you shoot?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 19-01-2013, 23:12
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
thanks for adding entertaining pop-ups. That made me watch until the end so I could discover you guys also have time to build an ominous rube goldberg device!
Unread 25-01-2013, 01:21
philso philso is offline
FRC #2587
How is your motor holding up? We burnt out the bearings on a mini-CIM with a similar wheel attached directly to it's shaft.
