Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 08-01-2013, 14:53
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
Re: Assisting a Climb
Originally Posted by ptkunapuli478 View Post
I don't believe that the floor is considered part of the pyramid in regards to climbing because there are no real field structures on level 0. Our team's understanding of the rules is that a robot (say, robot A), that is fully supported by the pyramid (i.e. hanging on its own), can help support another robot (robot B), which is being partially supported by Robot A.
I feel that you have to regard the floor as part of the pyramid. If it's not part of the pyramid, than it becomes hard(impossible?) to contact the pyramid at level 0 for the sake of a legal climb by the rule in 3.2.4.2
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
A. sequential order (Level 0, 1, 2, 3) during ascent and
B. no more than two (2) Levels simultaneously.
In terms of the idea of carrying another robot up the pyramid, i think it would still be rendered an illegal climb because that robot is not being directly supported by the pyramid.
I don't see a rule dictating a necessity to be supported by the pyramid to be considered for a scored hang, though I may be missing it.
Even if it were, I predict that refs would call that illegal because the second robot is indirectly in contact with non sequential rungs on the pyramid.
When it comes to lifting a robot up with you, I don't think it would violate the non-sequential rungs rule by indirectly being in contact with another robot touching a higher rung. I would think this contact wouldn't be transitive, but I admittedly have no rule I can find backing up this statement.
