Go to Post You know you've been involved with robotics too long when you see a remote-controlled traffic barrel coming up behind people and honking - and it doens't faze you. - GaryVoshol [more]
Unread 07-01-2013, 20:17
TheChosen1 TheChosen1 is offline
Software Wizard
FRC #2840
TheChosen1 is an unknown quantity at this point
Pyramid Dimension Contradiction
Has anyone else noticed the difference in width of the pyramid bars between the game manual here: http://frc-manual.usfirst.org/viewItem/3#2 and the prop construction .pdf here: http://www.usfirst.org/sites/default...c_Drawings.pdf ? It may create some confusion when testing the robot for our team.
Unread 07-01-2013, 21:42
Aren Siekmeier's Avatar
on walkabout
Re: Pyramid Dimension Contradiction
This also appears (I don't know yet to what extent) in the .STEP version of the pyramid provided by Autodesk. The top rung ends up short of 90" off the floor (bringing the whole top goal down with it), and the angles are off (exactly 60deg in the corner and almost 68deg on the side, as opposed to the other way around as advertised in the manual). The base also does not match the 94" spec in the manual. Somehow, however, the first two rungs are in the right positions. It would be nice to have some clarification on this, for sure.
I haven't yet been able to import the Pro/E files into Solidworks, so I don't know what issues that may or may not have.
Unread 07-01-2013, 23:25
Jack5885's Avatar
Jack5885 Jack5885 is offline
FRC #2840 (Blue Tide Robotics)
Team Role: Driver
Jack5885 is an unknown quantity at this point
Our team has spent hundreds of dollars (a bit under a grand I think) on building the Pyramid along with other field pieces. This is a major problem that needs to be addressed.
Not only is it out of the official competition spec, but the entire pyramid is completely unstable. The top twists around and is completely unsuitable for any kind of robot hanging activities. We will probably weld in cross-members to support it, but doing so could block our robot from climbing the pyramid-depending on our design.
Out team can't afford to throw that kind of money around if things that were supposed to be tested don't work.
Unread 08-01-2013, 15:11
Norsk Norsk is offline
FRC #3662
Norsk is an unknown quantity at this point
Hey what schematic did you use to make your pyramid? could you provide a link? i found http://www.usfirst.org/sites/default...c_Drawings.pdf
But it seems overly complex, is there a schematic somewhere with the pyramid spec on just one page.
Unread 08-01-2013, 15:47
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The game manual's probably +/- 1" since it isn't clear on whether the dimensions represent the center or outer diameters of the pipe. I would trust the technical drawings FIRST put out over any other representation, if you really are designing for such a precise measurement. However, I think the angles are still mostly correct for the face vs corner views. If viewing the pyramid from corner to opposite corner, the dimensions of the top and base are not the same as what they are if the pyramid is viewed from a side, face to face (thus they're ~61 degrees in the corner perspective vs ~68 degrees in the side perspective).
I suppose it's more about exactly how FIRST designed the pyramid for manufacturing vs how they communicated the design to AutoDesk. If FIRST made an exact 68-degree angle on the sides, then the top would come up short (and be slightly narrower than advertised too). Yet if they made the top rung a precise width (more likely, I think), and the base a precise width, then they did some rounding with the advertised angle. If Autodesk took the rounded angle as an exact angle, there's a discrepancy in communication between FIRST and AutoDesk. I haven't tried to pull in the AutoDesk model yet; we've only been working in 2D sketches for the time being as we proof things.
But again, we're taking it as "90 inches -ish, probably". It's easy to make a tolerant design for climbing either pyramid dimension, IMO.
GitHub
Unread 08-01-2013, 16:15
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
I was looking at the Autodesk Inventor one and all the angles I could measure all measured out at 68.9...which is a new measurment.
Academic Student (Forever)
Unread 08-01-2013, 16:53
Undertones's Avatar
Undertones Undertones is offline
Drive Coach
AKA: Mac
FRC #4334 (ATA)
Undertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond repute
I'm having troubles visualizing what the problem with the specs are. Can someone explain in a way that I am likely to understand?
Team 4334, Alberta Tech Alliance, Calgary Alberta
Western Canada 2016 Champions
Western Canada 2016 Creativity Award
Utah 2016 Champions
Utah 2016 Excellence in Engineering Award
Western Canada 2015 Innovation in Control Award
Utah 2015 Champions
Western Canada 2014 Regional Chairman's Award
Western Canada 2014 Champions
Utah 2014 Judge's Award
Western Canada 2013 Champions
Western Canada 2013 Innovation in Control Award
IRI 2012 Champions
Archimedes 2012 Champions - "The Eh Team"
GTR East 2012 Highest-Seeded Rookie
GTR East 2012 Cooperition Award
GTR East 2012 Rookie All-Star
Unread 08-01-2013, 17:38
misterli misterli is offline
FRC #1230
misterli is an unknown quantity at this point
Is it possible to purchase the pyramid from FIRST?
Unread 08-01-2013, 18:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
No.
Unread 08-01-2013, 18:38
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I'm not sure where you're getting 68.9, but that's approximately the angle between the diagonal and the rung when measuring in the plane of a face of the pyramid.
The 60 comes from measuring the angle between the diagonal and the floor (or a plane determined by a set of rungs); the 68 (IIRC, 67.72) comes from projecting that angle onto a vertical plane parallel to an edge of the pyramid base.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 08-01-2013, 18:48
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
http://www.youtube.com/watch?v=7KiVR9rmEgc
In this video, Andy says that AndyMark may offer one for purchase - could be an option if you are unable to build one yourself.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 08-01-2013, 18:55
CalTran's Avatar
MST Rolla Senior
I measured from the diagonal to the pyramid base plate
Unread 08-01-2013, 19:16
slijin's Avatar
Pockets
AKA: Samuel Lijin
Did you measure to the plane of the base plate, or a line in the base plate? There is a distinction.
Unread 08-01-2013, 19:17
on walkabout
This same issue being discussed across a few threads now...
http://www.chiefdelphi.com/forums/sh...85#post1210885
http://www.chiefdelphi.com/forums/sh...64#post1210364
Does anyone know if this issue is also present in the Pro/E version of the field?
Unread 08-01-2013, 20:14
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
I built one of the pyramids according to the plans for the competition field for the Peachtree Kickoff. It should be part-for-part interchangeable with the ones FIRST has built.
There is a 60 degree angle between the legs and the floor. That is, if you start at the top of one leg, go to the floor, draw a line to the diagonal leg, the angle made between the leg and the floor is 60 degrees.
If you start at the top of one leg and go to the floor, then to either of the adjacent legs, I measure an angle of about 67-69 degrees. I was using a very small protractor, however, so I'm not sure of the exact angle, but it is in this range. Looking at the pyramid from the side, the side view or view you get by projecting the vertical image on a flat surface gives a base angle, according to the plans, of pretty close to 68 degrees.
The outside dimensions of the rungs, going vertex to vertex of the rungs is
Middle Rung = 50.63 in.
Lower Rung = 75.13 in.
This assumes the weld adds nothing to the length, that is, the weld is ground down to the original tube dimensions at the corners. On my pyramid, I haven't ground down the weld and don't intend to, so our lengths are somewhat longer.
I'll have to wait until we assemble the pyramid again to get an accurate dimension on the rung heights. We are painting the pyramid now.
Remember that the pyramids are made of tubing, not pipe. Pipe is sized by internal dimensions, tubing is sized by outside dimension. The DOM tubing used in the official pyramids has an OD of 1.50 in.
If you are building a pyramid from the Team Built plans, be careful. Team built plans call for 1 1/4 in. water pipe which has an outside diameter of 1.66 in. If your robot design depends on clamping or hooking the tubing, be aware that the diameters will be different.
I would suggest that teams building a pyramid use EWR tubing which is "good enough". The finish isn't quite as smooth, there is a weld up the length (which may create a bump inside the tube, but the cost is much more reasonable.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
