Go to Post I volunteered to be the person responsible for the electronics and raised my hand before realizing that I have had almost no electronics experience. I hope our robot turns out alright... - Blue_Mist [more]
Thread Tools Rating: Thread Rating: 8 votes, 4.63 average. Display Modes
  #76   Spotlight this post!
Unread 08-01-2013, 15:27
NanoCollins's Avatar
NanoCollins NanoCollins is offline
FRC #1706
NanoCollins is an unknown quantity at this point
Re: How to pick up a frisbee
Originally Posted by Wildcats1378 View Post
That's the easy part. The hard part is determining which way they are facing, and then how to flip them.
I think that picking up the frisbees is going to be a waste of time. There's a pretty small number sitting on the field, and the main way to get most of the frisbee's is through the feeding station.
However, I was thinking of a conveyer system which would have a little hatch open. Above the hatch would be a suction cup on a piston. It would go down, pick up the frisbee, then deposit it on the conveyer belt. Simple and fast. Doesn't solve the upside down issue though...
From what I have seen from other people's test, it does not matter all that much how they are flipped. Upside down or not (depending on your shooting system and the distance) they should fly fairly well.
  #77   Spotlight this post!
Unread 08-01-2013, 16:07
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We bought a few suction cups at ACE for about $0.50 ea. along with a 3" ABS tube and some screws. It works quite well, actually, we just have to figure out how to get them from the suction cup to the hopper/shooter.
  #78   Spotlight this post!
Unread 08-01-2013, 17:12
3044smike's Avatar
3044smike 3044smike is offline
FRC #3044
3044smike is an unknown quantity at this point
Lightbulb Re: How to pick up a frisbee
my team had a few ideas for flipping the disks but the one i like the most is a system where the disks actually come into the robot on the side and then at the end there would be a little motor with two sticks with gear interactable teeth (don't know what they're called ) which would push the disk one way or the other based on a distance sensor. Any thoughts?!?
Team 3044 Ox: BE4
http://www.team3044.com/
http://www.usfirst.org/frc
I have a image of a DVD REWINDER
  #79   Spotlight this post!
Unread 08-01-2013, 17:15
3044smike's Avatar
FRC #3044
Exclamation Re: How to pick up a frisbee
my team did a little testing and the upside down frisbees are fine and dandy for about 20 ft if you can throw it really hard with alot of spin but then it just drops like a rock
flipping disks might still be important
Team 3044 Ox: BE4
  #80   Spotlight this post!
Unread 08-01-2013, 17:22
Libraryfanatic Libraryfanatic is offline
AKA: Geordan
FRC #2826 (Wave Robotics)
Team Role: Student
Libraryfanatic is an unknown quantity at this point
Originally Posted by MrTechCenter View Post
Sure it's much easier to go across the field to your alliance's feeding station and grab four discs, but think about it. After autonomous mode, you'd have 3 robots fighting for discs at the alliance feeding station. Sure there's enough slots for all three to be filled at the same time, but realistically, all three would not be fed at the same time, as the corner is very small and can barely fit all three robots there assuming that they are average sized. Plus, you have to worry about d-bots getting in your way and defending your feeding station. If you can pick up discs from the ground quick enough, it would be a HUGE advantage to you, and it would be beneficial during autonomous too, because then you can pick up discs from the ground and shoot them during auton for additional points (after you've shot your preloaded discs). And as for there being a lack of discs on the ground, the goals are fairly large but with the amount of defense that's possible, I can see a LOT of missed shots when a d-bot knocks a scoring bot off of alignment. We saw this last year with fender-shooters and d-bots.
There are three feeder stations-no competition at a given station.
  #81   Spotlight this post!
Unread 08-01-2013, 17:47
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
Well, I've flipped sides on collecting off the floor. I was pretty adamant in an earlier post about off-the-floor collection, but I have to say I agree with Joon now. Collecting will be a definite advantage, and in the final 30 seconds I could see teams scoring a lot from the discs thrown across the floor. Also, teams will probably miss at a higher rate then 85% unless they're "elite". And there's a reason there aren't that many "elite" teams. Picking up, I think, is going to be a very good thing to have. And yes, I everybody permission to make fun of me for flip flopping like this on this issue.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
  #82   Spotlight this post!
Unread 08-01-2013, 18:21
3132MentorMike 3132MentorMike is offline
Set the bar higher than you imagine
AKA: Mike Heimlich
FRC #3132 (Thunder Down Under)
3132MentorMike is a jewel in the rough3132MentorMike is a jewel in the rough3132MentorMike is a jewel in the rough
All good engineers proudly say, "I was wrong" if the data supports it.
  #83   Spotlight this post!
Unread 08-01-2013, 18:35
bobbyball bobbyball is offline
FRC #1243
bobbyball is an unknown quantity at this point
Originally Posted by kuraikou View Post
But than how would you put them into your shooter?
just use a pully and belt system upwards
  #84   Spotlight this post!
Unread 08-01-2013, 18:36
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Rishabhgadi View Post
Our team has been debating whether to use a shooter, or an arm. we have a prototype shooter but not an arm...Any input?
So you're going only for the LOW GOAL? Maximum extension of an arm is ~5" short of the MIDDLE and ~20" short of the HIGH GOAL.
(since 2004)
  #85   Spotlight this post!
Unread 08-01-2013, 18:37
FRC #1243
it will have to depend on the constictors of the belt shelfs
  #86   Spotlight this post!
Unread 09-01-2013, 07:10
Dan Oelke Dan Oelke is offline
FTC #5926 (The Things)
FRC #3023 (Stark Industries)
Dan Oelke is an unknown quantity at this point
I created a prototype last night to sweep up the frisbee. This was using a 3/8" piece of plywood with about a 1/8" gap under the plywood. The frisbee would pretty consistently pop up onto the ramp.
There are 2 small wheels by the front edge. The idea being that those wheels will keep it from catching on the bump in the carpet. This also had 2 castors on the back edge of the ramp putting it about 4" off the ground.
http://www.youtube.com/watch?v=M7JbdU4h6F8
  #87   Spotlight this post!
Unread 09-01-2013, 12:59
Wyrdash Wyrdash is offline
FRC #0236
Wyrdash is an unknown quantity at this point
It looks like this prototype is using hard brushes, something more sticky, or at least not dry nylon brushes will probably work better.
  #88   Spotlight this post!
Unread 09-01-2013, 13:07
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Those would be rack gears.
Why would you need to push the discs one way or another? Would you have two shooting mechanisms?
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #89   Spotlight this post!
Unread 09-01-2013, 13:50
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
All this talk of weather to pick up from the floor or the feeder slots. I dont realy think it is that hard to pick up from the floor and I have devised a realy simple disk flipper that is integral to the conveyor and needs NO SENSOR. So, why not do both. If you are picking up from the floor then you have some kind of hopper. If you have a hopper then it should not be that difficult to collect from the feeder tubes. For that matter, if you can pick up from the floor you can pick up from the floor right in front of the feeder station. Put a sign on the bot for the human player " feed to floor".
I'll post a vid later showing the flipper.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
  #90   Spotlight this post!
Unread 09-01-2013, 13:51
Bruceb's Avatar
Additional note. Look at the flipper this way. If you lay the disk on the floor the leading edge of the disk is HIGHER if the disk is upside down. Yes, there is your hint.
Bruce
