Go to Post According to Clarke's third law, I believe their entire robot works by magic. - dtengineering [more]
  #76   Spotlight this post!
Unread 06-01-2013, 23:57
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: Climbing Rules
Originally Posted by 3.1.5 (or 3.2.4 in the PDF)
Points are awarded to ALLIANCES per the details below. Final scores will be assessed five (5) seconds after the ARENA timer displays zero (0) or when all elements come to rest, whichever event happens first.
I think that makes it pretty clear that the official score is based on the position of the robot(s) (and Frisbees) 5 seconds after the end of the match
Jason
  #77   Spotlight this post!
Unread 07-01-2013, 09:26
pfreivald's Avatar
AKA: Patrick Freivald
Re: Climbing Rules
I agree, and assume they'll clarify early on.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #78   Spotlight this post!
Unread 07-01-2013, 12:34
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Re: Climbing Rules
So I have a thought concerning the legality of grabbing the second bar while on the ground.
You'll note that the rules specify:
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
A. sequential order (Level 0, 1, 2, 3) during ascent and
B. no more than two (2) Levels simultaneously.
However the Pyramid is defined as
PYRAMID: the Red or Blue steel structure on which ROBOTS CLIMB for points.
The carpet beneath the period is not a part of the steel structure, and therefore not a part of the defined pyramid. So, as long as you were to contact the Level 1 structure first, it could be legal to grab on to the Level 2 structure, while being in contact with the carpet, as you are not contacting the pyramid itself in Level 0.
That may not be intent of the rules, but the wording is very strange. The pyramid is defined as just the steel structure, and doesn't mention including the carpet beneath. And given that Figure 3-4 seems to show Level 0 as being below the actual structure of the pyramid, is it even possible to contact the pyramid in Level 0? Perhaps a rewording of 3.1.5.2 is necessary?
  #79   Spotlight this post!
Unread 07-01-2013, 12:39
pfreivald's Avatar
Re: Climbing Rules
It's been noted. I'm sure it will be clarified quickly in the Q&A or team updates!
Team 1551
I write books, too!
  #80   Spotlight this post!
Unread 07-01-2013, 13:08
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Climbing Rules
I am unable to find the blog post where Frank discusses it, but this sounds like "lawyering". The intent, I believe, is for the robot to be supported only by the individual level before moving on to the next level.
Of course, a Q&A submission and team updates will say for sure what the ruling on this is.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #81   Spotlight this post!
Unread 07-01-2013, 13:16
Re: Climbing Rules
No disagreement from me, I imagine the you are correct about the intent and this is definitely a lawyering of the rules. Simply trying to point out a possible oversight so that it can be addressed properly.
  #82   Spotlight this post!
Unread 07-01-2013, 17:37
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Climbing Rules
I think the manual makes it pretty clear that the floor is Level 0. Thus, you have to be completely supported by Bar 1 to touch Bar 2 and have it be part of a legal climb.
  #83   Spotlight this post!
Unread 07-01-2013, 17:56
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Climbing Rules
It would be great if the GDC puts out an update that includes diagrams of 'robots' climbing and showing legal and illegal climbing intermediate positions-- especially in relation to the floor and/or leg floor plates. Also examples that involve touching the legs of the pyramid. Sort of like they do for Ok/Not Ok bumper configurations.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #84   Spotlight this post!
Unread 07-01-2013, 18:09
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Climbing Rules
Originally Posted by Dinoyan View Post
Climbing the PYRAMID is the big deal this year
"how" we're going to climb the PYRAMID?
The simple way is the best may be Pnaumatics
TEAM 1946-Tamra
  #85   Spotlight this post!
Unread 07-01-2013, 21:28
Re: Climbing Rules
It isn't quite so clear about the floor being part of the pyramid, though. This is one spot where I expect an update to the rules.
  #86   Spotlight this post!
Unread 08-01-2013, 17:18
cgmv123's Avatar
AKA: Max Vrany
Re: Climbing Rules
But for the purpose of climbing, the floor counts as a level. It doesn't matter whether or not it's part of the pyramid for the purposes of climbing.
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID and/or the floor (Level 0) in
  #87   Spotlight this post!
Unread 08-01-2013, 17:24
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Climbing Rules
(to give Alan some credit, this was just clarified in the rules update today )
  #88   Spotlight this post!
Unread 08-01-2013, 23:17
Bob Steele's Avatar
AKA: Bob Steele
Re: Climbing Rules
Yes Alan successfully predicted the update!!!
:0)
Before the update it was not clear that floor contact made any difference in climbing.
  #89   Spotlight this post!
Unread 09-01-2013, 14:32
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Climbing Rules
Well, the rule change clarified whether you can touch the floor and bar 2 at the same time - Not!
Another scenario:
The bar is at the top of a level. When you grab on the bar, part of your apparatus is above the bar, and in the higher level. Since it is not touching the pyramid above the bar, that is not a problem.
Issue:
What if you are grabbing at the corner? Or, if you want to grab the corner? Then, you will come into contact with a portion of the vertical pole that is above the horizontal bar.
Question:
Is there a portion of the vertical pole, immediately above the bar, that can considered part of the lower zone if another portion of the robot it touching the pyramid in the lower zone?
If you are below the bar, then you want to be able to grab the corner and climb up, and incidentally be contacting the pyramid in the higher zone. Similarly, you could be a fraction of an inch above the lower bar, be contacting the vertical bar a fraction of an inch above the corner, grabbing onto the next higher bar, and should be considered as touching the higher zone (not touching any other part of the pyramid in the lower zone).
It would be helpful to allow the 5 inches (or whatever nominal amount) of the vertical pole above a corner to be considered part of the lower zone if the robot is touching any other part of the pyramid in the lower zone. Or, for purposes of the 2 zone rule, the 5 inches of the vertical pole immediately above a corner is considered to be in whichever zone (actual zone, or immediately lower zone) that is most advantageous for the robot.
  #90   Spotlight this post!
Unread 09-01-2013, 14:40
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Climbing Rules
Originally Posted by rich2202 View Post
Well, the rule change clarified whether you can touch the floor and bar 2 at the same time - Not! ...
I'm not sure what you mean. The second bar is between Levels 2 and 3--certainly that's well out of the realm of "sequential" with zero regardless of what fraction of an inch they could ever allow in tolerance...
