Go to Post A challenge to those of you grumbling about the refereeing this year: Be a referee next year. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
  #166   Spotlight this post!
Unread 08-01-2013, 13:05
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: Climbing Mechanism Ideas
Originally Posted by Rishabhgadi View Post
That was my initial idea, but you would not reach past the first level because of the notches on the side which stick out about an inch.
You could have a mechanism that grabs onto the notches lift you up just enough that you can then go back to climbing the rail
  #167   Spotlight this post!
Unread 08-01-2013, 14:15
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Originally Posted by Alex.q View Post
(I say someone and not me because I am just an alum and my team doesn't want to climb past lvl 1).
Hey! Not precisely true! We're prototyping for both level one and level three designs!
On another note, perhaps a dual engagement version of 2056's 2010 climbing mechanism would work. The first "climber" contacts the module, and the robot is lifted to vertical (or maybe so that the side of the robot is roughly parallel to the side pole, rolls up to the first bump, at which point the second set engages above the bump and the first stage disengages. Repeating this process would lead to a "hand-over-hand" approach to climbing the side.
Of course, balance would be a possible issue here...
Challenges like this are what makes FIRST so fun!
  #168   Spotlight this post!
Unread 08-01-2013, 14:57
MrBydlon's Avatar
MrBydlon MrBydlon is offline
AKA: Jeremy Bydlon
FRC #3313 (Mechatronics)
MrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud of
This is EXACTLY what our team originally talked about! We based our original thinking off of Team 33 Killer Bees' hanger arm but essentially the same idea. A tumbling robot up the pyramid. The first arm would rotate the robot 180 degrees. Then the second would grip and flip the robot over again and so on.
Our new thoughts have gone in a direction of two arms and a horseshoe shaped wide robot. Lots more prototyping to do...
Head Coach
FRC Team 3313 Mechatronics
Alexandria, MN
2014 10,000 Lakes: Chairman's Award Winner
2014 10,000 Lakes: Winner with 2052 and 2227
2014 Lake Superior: Finalist and Engineering Excellence
Website Twitter Facebook YouTube
  #169   Spotlight this post!
Unread 08-01-2013, 16:46
AKA: Nick Aarestad
Actually we were thinking sans the tumbling, as that seems overly complicated. As much as I love to see robots flipping over, it seems slower and more prone to failure than a (fairly) straight shot up the pyramid.
Do you think that the horseshoe is an inefficient use of perimeter? Or is it really just having an open side? I am interested in seeing what mechanism makes that make sense though...
  #170   Spotlight this post!
Unread 08-01-2013, 18:00
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
If what you mean by a horseshoe shaped frame is a frame wih a cutout on one side for an intake mechanism or for climbing purposes, it does not get included in the 112 inches of robot perimeter; the perimeter is the convex frame of the robot, so it does not include cutouts. See the rectangluar robot picture in Rule R03, figure 4.1.
I think there will be teams that manage to climb by repeated flipping the robot as previously described, but in my understanding, it would require a failry flat and symmetric robot, which could heavily constrain the designs of a shooter and hopper.
  #171   Spotlight this post!
Unread 08-01-2013, 18:15
AKA: Nick Aarestad
Ah. Thanks for explaining that. It makes more sense now.
I'm betting there will be teams that do it too. I am fairly sure you could do it with a rectangular-ly shaped robot in non-three dimensions, if the superstructure was supportive enough. I would see it as attaching the first side face, then pulling up, then attaching from the top of that face, and pulling up, and so on. Of course, that's just a concept.
  #172   Spotlight this post!
Unread 08-01-2013, 20:12
Oakley Marie Oakley Marie is offline
FRC #1610
Oakley Marie is an unknown quantity at this point
  #173   Spotlight this post!
Unread 08-01-2013, 22:01
mendeleev79 mendeleev79 is offline
Robot Rookie
AKA: Trevor
FRC #3620 (Average Joes)
mendeleev79 is an unknown quantity at this point
Not sure if this idea has been said yet, but I thought it might work to have a setup similar to the Team 2648 Breakaway bot (http://www.team2648.com/our-robots.html). If you have two of the arms shown on each end of the robot, it would be fairly easy to have one attach to the first level, lift the robot off the ground, and then have the second arm on the back attach to level 2. I don't think it would be feasible for it to reach level 3, but I thought it was a decent plan.
A problem with this, however, is that the first level is only 30 inches off the ground, which might make it difficult to accomplish the lifting mechanism shown.
Any ideas on this?
  #174   Spotlight this post!
Unread 08-01-2013, 22:34
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Any ideas on this?
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
A. sequential order (Level 0, 1, 2, 3) during ascent and B. no more than two (2) Levels simultaneously.
Emphasis mine
I'm interpreting this that you don't have to "climb" the first level, merely touch it. So maybe if you did a Robot-in-3-days-esque climber that barely lifts the robot at all, and that would be enough to "contact" the first level and continue on to the second.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
  #175   Spotlight this post!
Unread 08-01-2013, 22:42
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by F22Rapture View Post
Emphasis mine
I think the hard part is not re-contacting the floor once you've lifted yourself onto level one. A level-one chin-up will be difficult to turn into a level-two climb, methinks...
Those grippers that just don't slide when they grab a pipe might damage the powdercoat, and that might disqualify mechanisms from gameplay. (I'm not sure on that one, but it's worth considering.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #176   Spotlight this post!
Unread 08-01-2013, 22:43
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Emphasis mine
Points for the climb are awarded based on the zone lowest point on the robot occupies. If you touch level 1 but do not lift off of level 0 (the ground), you will be awarded points based on being "in" level 0, which is no points. You must lift off the ground to receive level 1 points.
  #177   Spotlight this post!
Unread 08-01-2013, 22:49
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I'm really worried about this, and I'm a little surprised there hasn't been more talk of it--am I missing something? I still like the 2010-esque latches (that can move out of the way of the horizontal crossbars) for this, but I don't even know how I'd know if they damaged the powercoat until competition time. Heck of a thing to be find illegal and lose 10-30pts/match over.
@Nuttyman54: you know you're agreeing with him, right? (re: "barely lifts the robot")
  #178   Spotlight this post!
Unread 08-01-2013, 23:38
F22Rapture's Avatar
AKA: Daniel A
My point was, if you go back and look at the video he linked, he expressed concerns that that mechanism wouldn't work because (paraphrasing) "it had to climb level one first, which is only 30" high." I was saying that because the wording of the rule is "contacts," it doesn't have to. It has to touch each level sequentially, and no more than two at once, but it doesn't have to climb each and every level.
So, my thought was, a mechanism that clearly touches the first level (by lifting the robot slightly) would be enough to satisfy that requirement before using the mechanism in the video to lift up to level 2, and hang for the 20 points.
- Wernher von Braun
  #179   Spotlight this post!
Unread 09-01-2013, 01:22
Jorge Ayala's Avatar
Jorge Ayala Jorge Ayala is offline
FRC #3478 (LamBot)
Jorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to behold
Is this legal? http://youtu.be/OY4BAbgWvdY
I see the robot being in more than two leves at the same time but only touching two.
Website
Facebook
Twitter
Victory goes beyond winning.
  #180   Spotlight this post!
Unread 09-01-2013, 01:26
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
I would say yes, after the hook is placed you are only contacting two levels (it looks like the track maybe contacting the 2nd level) the floor and first. Then after the lift, the robot is in level one only. When the second hook is deployed, you are in contact with on two levels again, making it still a legal climb and so on.
This was an idea I presented today, I think its a great one.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
