Go to Post Though winning is not the end, that doesn't mean it's not important. - Michael Corsetto [more]
  #31   Spotlight this post!
Unread 08-01-2013, 12:59
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: Linear Path Shooter vs. Circular Path Shooter?
Originally Posted by Jeffy View Post
My understanding of this is that he means the very short contact time and small contact area that a wheel and a linear wall creates compared to a curved wall and a wheel.
Oh.
Academic Student (Forever)
  #32   Spotlight this post!
Unread 08-01-2013, 20:08
dheerm's Avatar
dheerm dheerm is offline
Drive Team and Head Programmer
AKA: Dheer Mirchandani
FRC #0224 (The Tribe)
dheerm will become famous soon enough
Related Physics Question:
Take 2 different sized wheels with the same material making the outer edge.
Wouldn't the bigger wheel cause the frisbee to exit the shooter faster due to faster tangential velocity on the wheel?
"All you need is duct tape and a dream"
Team 224:
District Champions @TCNJ w/ Team 56 and Team 293
8th alliance captain at MAR championships w/ (take a guess) , Team 56 and Team 293.
www.team224.com
  #33   Spotlight this post!
Unread 08-01-2013, 20:21
http://www.chiefdelphi.com/forums/sh...2&postcount=16
  #34   Spotlight this post!
Unread 08-01-2013, 21:00
dheerm's Avatar
It translates into approx 21 mph, assuming no slipping.
3600 rpm / 60 min/sec = 60 rev/sec
60 rev/sec * pi*4/12 ft/rev = 62.8 ft/sec
62.8 ft/sec / 2 = 31.4 ft/sec
31.4 ft/sec * 3600 sec/hour / 5280 ft/mile = 21.4 mph
Why did you only multiply by pi and not by 2pi? Also why did you divide by 2?
(I might just be missing something but I thought linear velocity was Angular Velocity(in radians) * r?
Team 224:
www.team224.com
  #35   Spotlight this post!
Unread 08-01-2013, 21:06
dheerm's Avatar
Also, I understand that linear velocity at the edge of the wheel increases with a bigger wheel. I was unsure about whether that entire increase would still go into the frisbee
Team 224:
www.team224.com
  #36   Spotlight this post!
Unread 08-01-2013, 21:37
because the wheel circumference is equal to pi times the diameter
because the speed of the exiting frisbee is theoretically half the speed imparted to the frisbee's circumference (assuming, as stated in the post, that there is no slipping, i.e. the frisbee is rolling along the non-motorized edge)
That's correct. Punch the numbers and you'll get the same answer.
  #37   Spotlight this post!
Unread 08-01-2013, 21:41
The faster the tangential velocity, the more likely that the explicitly stated "no slipping" assumption won't be entirely accurate.
  #38   Spotlight this post!
Unread 08-01-2013, 21:45
dheerm's Avatar
So in other words, a bigger wheel "might" speed up the frisbee's exit velocity?
Team 224:
www.team224.com
  #39   Spotlight this post!
Unread 08-01-2013, 22:44
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
And that is why you prototype
  #40   Spotlight this post!
Unread 08-01-2013, 23:13
dheerm's Avatar
Exactly what I'm working on tomorrow Reason I was asking these questions was so that I could have some direction in the modifications I make to my prototype, but oh well
Team 224:
www.team224.com
  #41   Spotlight this post!
Unread 08-01-2013, 23:18
It's highly likely, everything else being equal*.
* same wheel speed, same compression, same wheel material, etc etc
  #42   Spotlight this post!
Unread 08-01-2013, 23:53
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
When making prototypes, keep in mind there are more variables than just linear versus curved.
Our linear prototype currently worked AWESOME, and our curved is merely pretty darn good.
We're smart enough to realize we haven't proved anything yet, and need to explore more.
As Adam stated, there are many variables that need to be identified and worked out before any designs are made. The following video and the one posted yesterday are proof that prototyping works.
The four things that changed between yesterday and today are:
Larger wheel (6in to 8in).
Different tread to reduce slippage.
Much more solid backing to the wall.
[Edit] Added traction tape to the wall to stop slipping. [/Edit]
The result is, we can run the wheel at a lower RPM and get much longer and repeatable flights. This will allow us to also have more headroom in the drive for faster spin up and shorter recovery time.
Can anyone say "Bang Bang" Speed Control"?
Yesterday's
http://www.youtube.com/watch?v=Wa6pc...ature=youtu.be
Today's
http://www.youtube.com/watch?v=_iqd_...ature=youtu.be
  #43   Spotlight this post!
Unread 09-01-2013, 00:28
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
NIce video but w a y to m u c h s l o w m o
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
  #44   Spotlight this post!
Unread 09-01-2013, 00:50
billbo911's Avatar
I'll pass that on to the editor.
But remember, we are using these for analyzing a prototype, not for entertainment.
  #45   Spotlight this post!
Unread 09-01-2013, 00:59
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
They are very useful. But a bit long to get through
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
