Go to Post See... this is what I love about my friends in FIRST. They come forward to help me whenever I need anything. - Arefin Bari [more]
Unread 08-01-2013, 19:53
Tao's Avatar
Tao Tao is offline
AKA: Dana Muenter
FRC #2838 (Eaglebots)
Tao is an unknown quantity at this point
Robot frame/bumper question
I'm totally new to the forum here so if I overlooked some rule, please let me know!
My team came up with a design, however we're not sure if/how bumpers would have to apply. Basically the frame would be the traditional rectangle, however about 1/4 of it at the corner would be cut out (like taking a corner piece from a cake). In the manual they diagram a rectangular frame with a section cut out in the middle, but not an entire corner.
Seeing as the bumpers need to cover all outside corners, would we need 8 in. bumper lengths for the inside of the cut out portion?
I might not be that good at articulating the question, so here's a quick MSpaint illustration!
On the other hand I'm very pleased with the new rule on being able to split up your team number on the bumpers, as long as it's identifiable. If only they had changed that for last year's game...
Also, if anyone is willing to divulge their secrets-- are y'all focusing on climbing the pyramid or scoring frisbee points?
Unread 08-01-2013, 20:02
Re: Robot frame/bumper question
Dana,
The definition of the bumper mounting and Frame Perimeter are inter linked. Since the Frame Perimeter is determined by wrapping a string around your frame. Bumpers are required on all exterior corners of the Frame Perimeter. Using the string to visualize, the ??? are not on exterior corners of the Frame Perimeter so no bumpers are needed. See also Fig 4-2 for a visual drawing of this.
Unread 08-01-2013, 20:41
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Wouldn't that perimeter require bumpers along the diagonal segment of the perimeter string? -- 8" from each vertex of the frame perimeter ?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 08-01-2013, 21:36
John,
I am of course working from a GDC interpretation from 2012 so the GDC response for 2013 will the deciding factor. I can see many teams thinking along these lines though.
Unread 08-01-2013, 21:37
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
yes, bumpers are required on exterior corners of the frame perimeter as measured by the 'string test'. I would be shocked if the rules were different than previous years that had the same language.
Unread 08-01-2013, 22:55
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
I've modified your original image to show the frame perimeter. Exterior corners do need bumpers, and I would regard your question marked corners as exterior, as they are common to the frame perimeter vertices. Figure 4-2 shows two corners that are not common to the frame perimeter, so do not require bumpers. However, please do regard a ruling from the GDC as kosher, and not mine.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 00:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It would. The 2013 rules state "at least 8 in. of BUMPER must be placed on each side of each outside corner" (R22).
However, the redefinition of the bumper rule (which is on balance a very good thing) apparently allows for an unconventional interpretation. The corner protection requirement specifies 8 in of bumper on each side of an outside corner, but does not specify that this 8 in must be measured along the bumper backing. (See attached.)
In fact, because the definition of frame perimeter continues to permit a skew polygon, multiple corners' 8 in dimensions need not even be coplanar, nor parallel to the floor in any given orientation.
Unread 09-01-2013, 12:27
Derpancakes's Avatar
Derpancakes Derpancakes is offline
Student Leader
Derpancakes has a little shameless behaviour in the past
If a diagonal bumper is required, that'd really throw a wrench into our plan.... We were hoping to use a mechanism inside the cutout that would allow us to climb.
Unread 09-01-2013, 14:02
AKA: Nathan Hui
One other thing: R04: In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME
PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
If a ROBOT is designed as intended and pushed up against a vertical wall (in STARTING
CONFIGURATION and with BUMPERS removed), only the FRAME PERIMETER (or
minor protrusions) will be in contact with the wall.
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 14:18
Tristan et al,
I am restating the 2012 interpretation of what defines the opening. If you use the string method then the indent is not on nor does it define the Frame Perimeter. Therefore the indent is not an exterior corner. As Bill Miller explained last year, should a team add something to the indent that is made the same as a bumper, it will not be a bumper and we were not to inspect anything that covered that area. By definition in 2012, only bumpers on the Frame Perimeter are in fact "bumpers". The GDC is the final response in the matter and they of course can change the interpretation for this year. This question needs to be asked in the Q&A.
Unread 09-01-2013, 15:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Your theoretical string defines the perimeter, not the actual frame. So the string stretched diagonally between the two corners- See Nathan's picture- define the perimeter that needs a bumper at least 8" from each corner. Like Tristian's picture So you will need a physical frame to back it up.
R22, Fig 4-2 shows an indention with no exterior corners. Not the case here.
Rule seems pretty clear to me. Hopefully Q&A will respond with something that clarifies this.
Unread 09-01-2013, 16:48
Tristan et al,
So, if you took a rectangular frame, but put a birdsmouth cut at each of the four vertices, there would be no exterior corners, and thus no corner protection requirement? I don't recall an official ruling to that effect.
I've always interpreted "exterior corner" (and "exterior vertex") to mean any vertex on the frame perimeter.1 The vertex defines it, not the adjacent legs of the frame perimeter (if any).
1 Or, in years where the frame perimeter is not a projection onto a 2-D plane, any vertex on the convex hull of the projection of the frame perimeter onto a horizontal plane.
Unread 09-01-2013, 16:59
After thinking about it for a minute more, I see which clause you're getting at—in 2012's Fig. 4-3, FIRST implicitly interpreted frame openings along the side of a robot as not being exterior corners by showing them as permissible despite not having an 8 in leg of protected frame perimeter on one side of the vertex. (This was convenient, because it allowed robots to have unprotected openings.)
That works for case of a 180° frame perimeter vertex—which can plausibly be said to be not a corner—but doesn't actually make sense in the general case, as we're finding in this thread. The lack of generality didn't occur to me last year.
I agree FIRST needs to issue a ruling on this one.
Last edited by Tristan Lall : 09-01-2013 at 17:16. Reason: Rephrasing for clarity.
Unread 09-01-2013, 17:29
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
What I remember from last year was that we assembled the KOP frame and we fitted the corners so the inside corners touched leaving a 1 inch gap looking like the OP's picture. We were told that the perimeter effectively had a diagonal in there and that it wasn't going to work. So we had a couple of kids spend three hours cutting and fitting pieces into each corner so we had a square corner.
This year the rules have been changed to allow up to 1 inch of bumper at a bumper end not having to be backed by the robot.
It will be interesting to see what the GDC rules. Hopefully it won't just be a blanket statement saying the GDC does not make robot design decisions.
-T
Unread 09-01-2013, 18:18
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Not only is it not a bumper, it also loses the bumper exemption to the weight limit.
