Go to Post As my daughter said, you used to shut up your robot and send it away from home. Now you just suffocate it. - GaryVoshol [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 08-01-2013, 22:43
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Climbing Mechanism Ideas
Originally Posted by F22Rapture View Post
Emphasis mine
I'm interpreting this that you don't have to "climb" the first level, merely touch it. So maybe if you did a Robot-in-3-days-esque climber that barely lifts the robot at all, and that would be enough to "contact" the first level and continue on to the second.
Points for the climb are awarded based on the zone lowest point on the robot occupies. If you touch level 1 but do not lift off of level 0 (the ground), you will be awarded points based on being "in" level 0, which is no points. You must lift off the ground to receive level 1 points.
